965 IC vs B&B IC
On the fence of putting a 965 IC on my 78. Currently there is a B&B IC on there.
The surface area is the same between the two. The B&B is much thicker, but is not a full bay. The 965 IC is approx 3/4 of a full bay.
While I don't have any numbers, it would seem the 965 may be slightly more efficient than the B&B due to the overall coverage vs thickness.
Does anyone have any stats on the two?
The plus side of the B&B is accessibility to other parts of the motor. I have removed the A/C btw as I do not drive this during the summer months and I can drop some weight off the back.
Thank you in advance for your input. Chris (Turbokraft) very interested in your feedback.
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 02-17-2023, 04:42 AM
dos531's Avatar
965 intercooler is probably more of a sidegrade than an upgrade. Not worth the trouble IMO. If you're looking to improve charge temps, go with the turbokraft full bay.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 02-17-2023, 08:32 AM
crb07's Avatar
There was a comparison of all half bays including Ruf and TurboKraft half bay has more cooling area.
Old 02-17-2023, 11:49 AM
That is where I am at, whether it is worth the trouble. May just sell it an put the cash towards my 71 project.
i will look for that comparison. I saw it years ago but it has been a minute.
Old 02-18-2023, 06:30 AM
I haven't had the opportunity to lab test the 965 IC against the B&B say at 18psi and air heated to 150F, I wish I could get my hands on one.
But in terms of a B&B vs the OEM 930 IC, the B&B is far superior. I did a bunch of these tests back in 2005 and the B&B faired extremely well.
In general terms, surface area is very important and directing moving air to this surface. But you also want a certain depth in the core without adding too much pressure drop, this is where the fine balance in thermodynamic / thermal efficiency design comes in.
Old 02-18-2023, 08:57 AM
Is B&B IC similar design to BS IC? I remember reading about this build.
930 rebuild -- the process in pictures.
Old 02-18-2023, 06:49 PM
Completely different designs. The Blown 6 IC is similar in design to the 965.
Old 02-19-2023, 03:44 AM
TurboKraft's Avatar
John
Both are pretty similar with regards to cooling efficacy under normal driving conditions. With the increased surface area, the 964T has a small advantage in situations where you are under sustained boost.
Both are more than adequate cooling capacity for a CIS-injected engine.
The 964T intercooler is a "longneck" IC fitting directly onto the throttle body and has the updated diverter valve setup which improves driveability. It's noticeable as soon as you accelerate from a stop. This valve doesn't leak boost like the stock (tired) diverter valve housings, so boost response is slightly improved.
A downside of the 964T IC, besides the aesthetics of it sitting at that wonky angle, is that there is interference with the rear AC condenser in the wing.
B&B bolt-on Standard Fit IC #FPOR-0300 core: 11x11x4.5in = 545in^3 volume, 121in^2 surface area
964T IC core: 22.75x8x2.625in = 478cid, 182in^2 surface area
TurboKraft LNIC: 17x8x4.5 = 612in^3 volume, 136^2 surface area
Kokeln: 16.25x8.5x4.5 = 622in^3 volume, 138^2 surface area
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-28-2023, 10:23 AM
Ic
Thanks Chris.
I have rebuilt the diverter valve once and seems to carry boost fine for the moment.
Still left on the fence which I guess mean’s leave it as is because I don’t see a compelling enough reason.
Old 02-28-2023, 02:02 PM
I went for TK Long Neck and cannot be any happier with the quality and the help that Chris gave during my install.
Old 03-02-2023, 04:39 PM
Axel84's Avatar
Both are good, splitting hairs really.
More than enough for your 500 bhp build unless you live in the desert.
Old 03-02-2023, 10:42 PM
