Turbo Bracket Re-install
Dumb question...I just replaced the 3LDZ with one from Evergreen. Now I am struggling to trying to reinstall the big turbo bracket as the holes are not even close to lining up. Did I do something wrong or does the turbo need to be re-clocked? Do I need to really put serious elbow grease to re-install the bracket?? I am reluctant to force anything and possibly break something.
Old 04-16-2023, 01:16 PM
Alan L's Avatar
Yes the turbo probably needs 're clocking'. There are some adjustments that can be made. A pic of how the bracket is sitting would help show what is out of place where. The main tweek is the small bolts joining the cold side to the body. This section rotates and it is highly likely the replacement turbo will not be in the same o'clock position as your old one. Rotating the body against the cold side changes the orientation of the studs on the hot side holding your bracket.
And you will have a V clamp on the hot side half also. Again you can tweek just the exhaust end studs using that.
It is normal to have to re jig things after changing turbos. They never seem to go back exactly the same way.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-16-2023, 04:28 PM
Here is the photo of the bracket. I did have a difficult time getting the oil line studs lined up. Greatly appreciate the help!
Old 04-17-2023, 11:15 AM
Alan L's Avatar
Right - so if you relax the V clamp and rotate the bracket up you should hit the studs.
The oil line fitting can be oriented by loosening both ends of the turbo and rotating the mid section.
Alan
Old 04-17-2023, 11:48 AM
Before I sent mine out for rebuild I scribed a line to allow me to return the housings to factory clocking positions. I realize this doesn't help you now, but future people looking for this info might find it helpful.
Old 04-17-2023, 02:18 PM
Alan
Thanks for the tips!!
Great idea! I bought a used 3LDZ and sent it to Evergreen for their Raptor-X upgrade
Old 04-18-2023, 01:22 PM
