Hesitation at 3000 rpm is GONE 👍
I used to have hesitation at 3000 rpm, like a fuel cut off issue.
It was the Ignition Distributor! The centrifuge weights were gummed up, so I sprayed the crap out of it with Brake Cleaner until the gunk cleared out. Then I used high temp anti-seize grease in all the pivot and contact parts. The reluctor advance was sticky too. After re-assembling everything I went out for a drive and was pleasantly surprised 😮 how smooth the rpm's were. Wow!
Check that distributor!!! Love it!!! Caress it!!!
Treat it right and everything will be alright.👍
Old 04-10-2023, 12:03 AM
