1979 930 Rough Idle "dieseling" and dies
Completely original, CIS, etc.
I was hoping that you guys could give me a good place to start... I have attached a link to my Youtube where you can hear it idling. I have replaced the two gaskets in the air recirculating body at the piston as I thought I had a vacuum leak. The overboost sender has been bypassed for testing...no change. When attempting to idle it is very rich...
I have read through the "my car won't start" sticky which is quite the daunting list.
If anyone has any ideas based on how it sounds it would be great...or should I just work the list in no particular order?
https://youtube.com/shorts/W9cEqV8W_uA?
Old 04-06-2023, 07:32 PM
Sounds like it's running too rich. Turn back adjustment screw, and or advance distributor to get a hotter spark.
Old 04-23-2023, 11:02 AM
Bucketlist's Avatar
From the audio I would give it some air at the throttle body and get the rpms up to 900-1000 and let it warm up. Have you tested your cold and warm control pressure, if not get a set of gauges and do some testing.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 04-24-2023, 03:47 AM
speednme1's Avatar
If you can get your hands on a pair of fuel relays, I would start there. Cheap and easy to do.
Rey....77 930 "the Mistress"
Old 04-28-2023, 12:15 PM
