Fuel Accumulator third outlet?
What connects to the bottom port on a three-port fuel accumulator? Does it serve as both a fuel pressure regulator and fuel accumulator?
Thank you! Last edited by Luislang; 05-05-2023 at 01:37 PM.. |
The bottom is a drain for leakage. It should go back to the fuel tank
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
