Cylinders
Has anyone used a set of 3.3 piston and cylinders from a 1991 964 turbo on a 1987? the cylinders measure the same with the head gasket shim they just use an o ring for the base. A friend of mine has a new old stock set I can get cheap. Thanks, Jason
I have a set on mine. I did not use copper gaskets just the o rings no leaks and just over 90k . Karl.
