-   -   Bad handling Yokohama A008P tire (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1140252-bad-handling-yokohama-a008p-tire.html)
Horch 05-19-2023 05:16 AM
Advice needed!
Ordered 4 new tires for my 930. Fronts 225/50/16, rears 245/45/16. I currently have Continental Sport Contact which I really like, but are old (6 years old).
Based on reviews here on the forum I ordered the Yokohama A008P's, which are specially designed for the classic 911.
It drives horrible. No direct feeling. Feels sloppy, almost dangerous, like I'm driving on bubble gum. Tire pressure is correct (2,0 bar front, 3,0 bar rear as with the Conti's).
Anyone with the same experience? I did contact Yokohama, because the rears do have the N0 code on the tires, but the front don't... They will look into it and contact met next week.
reclino 05-19-2023 05:26 AM
Following, i had planned on buying these tires. Interesting that the fronts are not marked N0.
Mr Beau 05-20-2023 01:23 PM
3,0 bar (45 psi) in the rear? Isn't 2,0 to 2,4 a more normal range?
Horch 05-20-2023 02:33 PM
It’s what the sticker in the rear and the manual indicates. Worked fine with the Conti’s…
patina 05-21-2023 07:20 AM
You need to run those tires at 29F 33R cold. 45 is insane.
Horch 05-22-2023 12:27 AM
Yokohama contacted me this morning:
205/55ZR16 = N0 rated
245/45ZR16 = N0 rated
225/50ZR16 = NOT N0 rated
Going for a different set of tires...
908/930 05-22-2023 11:00 AM
I would not worry about the N-0 (Porsche rated) part, I do not think that even existed when the 930 was available, just a proper speed rating listed on the tire.
In the owners manual Porsche does call for 44psi in the rear tires for the 930, also says it is valid for snow tires.
No experience with the A008p, but surprised they do not feel good, possibly need some miles on them? Years ago I had some Bridgestone re71 that has a soft sidewall and responded very slow, possibly similar problem.
dos531 05-22-2023 11:08 AM
It sounds like you're complaining that a vintage style tire drives like a vintage tire?
Jeff NJ 05-22-2023 11:41 AM
I found that 44psi is too much for my RE11s.
That pressure was for tires from the 70s and 80s. Current tire tech doesn't really need that much pressure and I find my car is more neutral handling with about 36 psi cold in the rears. I run 29 in the fronts.
Based on patinas suggestion, maybe I'll try 33 and see if it's better. I think I dropped it and liked what I had at 36, so I left it.
908/930 05-22-2023 11:51 AM
That Yokohama A008p is a W speed rated tire, far from vintage.
Porsche likely had a reason to suggest 44psi, possibly to make the rear end traction more forgiving?
Horch 05-22-2023 11:32 PM
All tires were sold to me as N-rated (also stated on the invoice), but fronts were not, so returning them. Just ordered the Pirelli p zero rosso asimmetrico's front and rear.
Maybe I expected too much from the A008P's, but compared to the Conti's, cornering is vague and high speed stability.... well, it's not there. Definitely not the right tire for me. Hope the Pirelli's suit my 930 better.
Thanks for all the suggestions/advice.
stownsen914 05-23-2023 07:35 AM
Tire pressure is very specific to tire brand. If you use the value from the sticker, you can easily see wide variation in performance from one tire brand/model to another. Incorrect pressure can easily result in the poor handling and feedback you describe. Contact Yoko and see what they recommend for that tire on your car.
bleucamaro 05-24-2023 11:36 AM
Are 6 year old tires really that old? On a garage kept car that's seasonally driven, I don't think its too old. . . on a highly loaded trailer that gets parked in the sun, maybe.
Horch 05-25-2023 12:06 AM
New Pirelli's installed! What a difference. Next month 5 days to the Alps to test them... :)
http://forums.pelicanparts.com/uploa...1685001891.jpg
james6speed 06-27-2023 06:16 AM
Horch, is that the Pirelli 205/55r16 and 245/45r16 combo in Rosso? How are they working out?
james6speed 06-27-2023 06:18 AM
Also, are those the Group 4 Campy's in 16x8 and 16x9? :)
Horch 06-27-2023 09:46 AM
Front 225/50/16, Rear, 245/445/16 and yes Campy's in 16x8 and 16x9. Like the Pirelli's! Tomorrow for 5 days to the Alps trying them out... ;-)
james6speed 06-27-2023 10:10 AM
Awesome! I just bought a set of the LMZ's in that exact spec for my next project and was wondering which tires will work best with it. Give us a full review after your trip. Cheers!
infraredcalvin 06-28-2023 08:00 PM
Car looks amazing, I love those wheels!
Horch 07-03-2023 07:17 AM
Back from the Alps. It was amazing. Car did very well, including high speed on the German Autobahn (> 200 km/h), as well as quick driving on the mountain passes. Love the Pirelli's. Stick to the tarmac like glue. I have 225 in the front and did find it more pleasant to drive with a litte more tire pressure in the front.
http://forums.pelicanparts.com/uploa...1688397459.jpg
pdx930 08-01-2023 10:34 AM
I bought a set of these to replace a set of Pirelli Corsas that had become roughly hexagonal after sitting. My first impression of them was that they were pleasantly round. Then I took them to an autocross and they have comically low grip and howl like wolves under a full moon. I played with pressure a bit and was eventually able to get them to stick a little bit @ pressures like 30f/32r, but as someone else said, they grip like the retro tires they are.
I have Pilot Sport Cup2's on my GT4, and after a weekend with about 40 runs on a brand new set of those, they were worn about 50%. I guess if there's an upside to the A008P's, after a similar number of runs they still look like new. If you want a round tire that will lower limits to the point where you can safely push the car on back roads, the A008P's are OK. If you are after a modern grippy tire, look elsewhere.
matsuzaka 08-01-2023 12:31 PM
I’m not familiar with those tires but I would like to point out that the factory recommends tire pressures of 29 front and 44 rear. If I remember correctly even my 88 Carrera called for 29 front and 39 rear. Both pretty far from what you were running.
pdx930 08-06-2023 10:06 AM
Factory pressures were recommended with 1987 (in my case) Pirelli p7 tires, which these are not, and with a particular handling balance in mind. They are not divinely revealed, let alone optimal with modern tires.
Lowering rears to around 32 improved grip quite a bit with these A008P's on the AX course. Lowering below 30 in the front decreased front grip. YMMV, but I played with this quite a bit and that's what I found with these tires, on my car, on that day.
That said, I still stand by my assessment that grip with these tires is comically low compared to several other tires I have had on this car.
Jeff Alton 08-09-2023 06:46 PM
Maybe consider a wheel alignmenet? A proper one, where caster and camber are set in the front. Post pics of the upper strut mounts once completed so we know it was done properly....
Run the recommned Porsche tire pressures....
macronbill 08-12-2023 12:02 PM
3.0 bar tires
porschke911 02-09-2025 09:55 AM
A008p
I know this is an old thread but I haven't been on in ages. I wonder if Yokohama is having quality issues. I bought these tires and fell in love with them instantly. They replaced R888R tires. My 911 is a 73 with a tuned 3.6 engine. Running F205/R245. I found these tires to have better grip than the TOYO. I also didn't find any howling with the tires except at the limit of cornering. I tracked the car and was very impressed with the tires. So much so that I have another set ready to install
patina 02-13-2025 01:33 AM
You are so confidently incorrect, ha.
44 psi is way too much for the rears. We have come a long way since 1987. Go drive one of these cars hard with the rear tires set to 44psi (more like 50 hot) then air them down to ~32 psi (hot) and report back.
patina 02-13-2025 01:35 AM
Are you sure you’re not running the A052? That would make more sense. I run the A052 and they are an incredible tire, I just wish they lasted longer.
