Help Identifying Fuse
Went to take the 930 out for a nice Memeorial Day drive and of course battery was stone dead. I replaced the battery 2 weeks ago so I figured there was a draw and sure enough I found one. My car does not have a fuse block sheet on the cover so I would appreciate help identifying exactly what the fuse controls. I know it covers the radio for sure but what else? It is the4th fuse from the left under the fuel pump relays and a 5 amp fuse. Can anybody check their fuse cover and help me out My car is a 1989 Cab.
Thanks in advance |
Looks like Clock, Radio, Interior lights. I will try to scan the paper.
Not a great scan but here it ishttp://forums.pelicanparts.com/uploa...1685411853.jpg
Thanks for the replies. Looking at the first scan it would be the clock, interior lights and radio but on the second scan it also lists AFR Guage. Is the second scan a factory diagram? Is that for a air fuel ratio gauge or something else?
If you have an AFR factory gauge that is where they would plug it in.
What you could do is individually pull wires from the fuse - to the individual bits. Put an ammeter across them and see what is drawing power with key off, and how much. Will it be enough to flatten the battery? Alan |
Thanks Alan
| All times are GMT -8. The time now is 05:58 AM. |
