1% Leakdown realistic on 80k mile car?
In preparation for selling my '86 930 I did a compression and a leakdown test on the engine today.
This is on a cold engine with 80k miles that has not been run in a few weeks. My compressions were performed simply by connecting the pressure tester with all plugs out, and cranking the engine a few seconds with WOT. All were 105-110psi. I measured the leakdown with my ATS differential pressure tester that I use on my airplanes. Rotated the engine to TDC compression stroke cylinder by cylinder, and used 100psi as the control pressure. Every cylinder was 98 or 99 psi. That is 1-2% leakdown. I did this twice around to make sure I did it correctly. These numbers aren't what I was expecting. I was expecting the compression to be a little higher, and the leakdown to be a lot lower. Is it really reasonable to expect 1-2% leakdown or did I do something wrong? To validate the tester was working correctly I watched the gauge as I (carefully) went past TDC and it did suddenly drop as the exhaust valve opened. I'm just surprised by the numbers I suppose.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! Last edited by flightlead404; 07-16-2023 at 04:33 PM.. |
What’s the problem? 1-2% leakdown is perfect.
Ole Skool - wouldn't have it any other way |
I guess I was just feeling it was a little too perfect
I was expecting in the mid-90% range. Its pretty hard to mess that test up though. At least, its hard to mess it up to make the pressure read higher (leakdown be lower). I just never see that kind of result on airplane engines, especially not mid-time engines. Never done it on a car before.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Leakdown is fine. Compression gauges vary. Specifically, the amount of tension on the spring inside the shrader valve in the end of the plug adapter. Try a different gauge.
It's possible that since your car sat for several weeks some engine oil seeped into the cylinders. This may contribute to 'false' comp readings. I think it's best to do a compression test shortly after warming up the engine.
MikeD '87 930 |
My compression might be lower because I have a higher lift, longer duration cam in there.
Oil in the cylinder would see out, not in, but would generally give both a higher compression and better leakdown. The compression and leakdown numbers being consistent across the board is good. IDK why I'm complaining about such good numbers lol
On most other cars even 10% leak down is great
