-   -   Lost Tune: Does This AFR Table Look Reasonable? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1152441-lost-tune-does-afr-table-look-reasonable.html)
flightlead404 12-20-2023 10:54 AM
I did something dumb and somehow reverted to an old tune, version unknown.
1986 930 stock internals except SC cams. Single plugged with COPs, running 1 bar of boost.
Does this table look correct and reasonable?
http://forums.pelicanparts.com/uploa...1703098343.png
dap930 12-27-2023 03:31 PM
Here is my AFR table for my 77' 930. It looks similar.
http://forums.pelicanparts.com/uploa...1703719847.jpg
s5uewf 01-23-2024 04:29 PM
Looks reasonable to me, too. I think mine is a little richer over boost, just because I figured some cooling factor and also gas around here is up to 10% ethanol ... my wide band and software uses lambda, so I think in theory the AFR delta (14.1 vs 14.7) is not an issue - but just in case of gas variations...
I can send you my fuel map if you are OK sending me an email. I can respond and attache the fuel and ignition map. I sent you a PM.
Good luck!
