-   -   easy cam timing tip (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1157742-easy-cam-timing-tip.html)
Alan L 02-19-2024 07:36 PM
easy cam timing tip
Well, for the 1-3 side anyway.
Just reassembling my engine after chasing a gremlin that I never really found - oil in #1 cylinder. So the outcome is uncertain. But I did stumble on a simple cam timing method.
I have only pulled the 1-3 side apart, so using the cam timing on 4-6 side to set #1Inlet.
I was looking for 1.75mm. So I set the engine to #1 TDC firing. I had all the rockers installed - but the valves backed right off (except #1 I which was at 0.1mm). I set my dial gauge on the #1 I rocker then rotated the engine half turn to #4TDC. This is the point the #1I should be open to my valve setting. I had the two drive bolts for the scavenge pump in the end of the cam. I just rotated those in the right direction until the dial gauge moved to my timing number - 1.75mm. It happened the cam was happy to sit there. I had removed the lock pin on the cam wheels and had the bolt finger tight so the wheels could rotate without moving the engine. Pulled the bolt - inserted the lock pin and cracked some torque on the bolt. Rotated evrything one more time and the timing mark came up exactly on what I had set. A one shot set at the timing.
Unfortunately it won't work for 4-6 as no drive pins in the cam end.
But dead simple, and every bit helps right?
Alan
Tippy 02-20-2024 09:05 AM
Great idea
