-   -   AFR meter (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1159463-afr-meter.html)
dr07845 03-27-2024 05:44 AM
AFR meter
What is the best AFR meter for use on several cars for tuning?
Thank you
Tippy 03-27-2024 12:48 PM
I’m a fan of AEM. Had had Innovate too.
nocarrier 03-27-2024 04:50 PM
Ballenger AFR500CAN
Toddrivers 03-29-2024 04:02 AM
Thank you
I guess the key to this question is "several cars" and I'm not familiar with most offerings. I have had pretty good luck with Innovate LM-2 on my car. With "several cars" in mind, you can use the cigarette lighter for power and there is a portable exhaust clamp available for moving the 02 sensor from one vehicle to another.
https://www.innovatemotorsports.com/lm-2-complete-kit.html
https://www.innovatemotorsports.com/videos/
Mike80911 04-03-2024 06:38 PM
Started a thread a while back about this very subject. Went with this one but not real happy with it.
https://www.aemelectronics.com/products/dashes_and_gauges/wideband_gauges/x_series_wideband/parts/30-0300?utm_medium=cpc&utm_source=google&utm_term=&ut m_campaign=Google+Shopping+-+AEM+-+Non-Brand&hsa_acc=3492467452&hsa_cam=20597687036&hsa_g rp=158234889240&hsa_ad=681255477517&hsa_src=g&hsa_ tgt=pla-2234885866721&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ ver=3&gad_source=1&gclid=CjwKCAjw_LOwBhBFEiwAmSEQA aJX5UXTxuCbiPeLa0vTJ8nOX6k54cJf6i_b8BpYM6_k6uxHwKz v2hoC6qQQAvD_BwE
Here is the thread
https://forums.pelicanparts.com/porsche-911-technical-forum/1147795-afr-gauge-setup.html
infraredcalvin 04-03-2024 09:38 PM
Another user of the innovate LM-2
I’ve heard of some that had noise or other setup issues, all solvable, I didn’t have any issues, just plug and play. I’ve updated the firmware a few times, now every so often it doesn’t log the 2nd O2 sensor, but it hasn’t been enough of a problem to try and troubleshoot…
I stuck with their products across 3 cars now so i can interchange sensors, wires, gauges, etc.
Chinook 04-06-2024 12:11 AM
Installed an AEM and the O2 sensor was dead out of the box. Sensor had no Bosch script (Probably counterfeit). AEM WOULD NOT STAND BEHIND IT. I resorted to another sensor from OReiley's that had Bosch script printed all over it which functioned correctly. No more AEM for me.
patina 04-06-2024 03:04 PM
Similar experience. The innovate stuff is much better made. Obvious as soon as you open the box.
Tippy 04-07-2024 07:06 AM
Exact experience minus AEM
giving me a 2nd counterfeit that failed quickly too. Like minutes.
Went AutoZone and bought legit Bosch 4.9 and all is fine for months now.
