Symptoms of a Failing CDI
Hey Guys - Took my '89 for a nice drive yesterday.
About 30-minutes into the drive the car stumbled and died and refused to start. I let it sit for a few minutes and it fired up right away. I decided to let it sit for an hour and proceeded home. On the way back every 10-minutes it would instantly shut off. If I let it sit for 5-ish minutes it would fire up without any issue and I was able to drive for another 10-minutes until it died again. Do you guys think this might be the CDI on its last legs? It's the original unit from '89. Thanks, Yasin
Ole Skool - wouldn't have it any other way |
Definitely could be the CDI. It starts to show symptoms of failure as the car gets warmer. The fact that you can restart and drive suggests against a fuel issue.
Bob Ashlock is terrific at rebuilding these CDI units for a very reasonable cost - fast turnaround too. https://ashlocktech.com/bosch-cdi
Tonger |
I would start checking electrical connections, could be a weak connection getting hot and expanding. Need to verify that there is no spark.
87 930, |
@Tonger - Thanks! I was looking at the Classic Retrofit units, but I'll call Bob Ashlock, I had not heard of him before or his CDI rebuilding services.
Much appreciated, Yasin
I have a good working when removed CDI from an '86 I'll sell, if it's the same part.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Most likely CDI, considering your symptoms. I guess you could further diagnose by placing a bag of ice on top of the cdi and see if that greatly extends the time between driving and shutdown....assuming it's heat soak related. Just a thought.
Another possibility might be relay under the drivers seat...overspeed relay I think its called. Years ago mine gave me fits with sudden shutdowns and the short term remedy was to reach under the seat and rattle things around. Eventually removed it and re-soldered all circuit board traces and spread the prongs on the plug. Did the trick.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Thanks guys. I'll will try the ice and also look at that overspeed relay (I did not even know about that one!).
Much appreciated.
Banned
Sir Yasin - bummage, dewd. Destiny for all, unfortunately with these 8 )
Likely CDI, but also as likely to be confounded yellow relay... or... gdamn fuel pump fuse & wire if you've not yet relayed your FP's individually (as you should have by heh heh!). HTH, report back! Good news is... least you have A DOZEN other f'n wundercarz to bomb around in until sorted!!! Mah MAN... ![]() ![]() ![]() ![]() ![]() |
I will report back for sure. On the cars...there are a back-up for the back up. Chat soon! Yasin
Any news on the problem?
Here's the M&W Pro10 CDI I was talking about if you're looking to replace with something besides Permatune. I wasn't able to find anyone making a plug and play harness though. https://outfrontmotorsports.com/products/m-w-pro-10-cdi-ignition-box
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Banned
here ya go brohammage!:
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/575052-930-fuel-pump-fuse-overload-solution.html on mine the red wire going into the fuse block was visibly cooked - give it a quick looksee if yours is (somehow lol, guaranteed failure) good, put it on your to do list I'd skip running the wires through the metal cover, that wasn't the best idea - but otherwise it's a quick and easy and IMPORTANT fix!! hope you find it soon dewdstick! |
David - I ended buying a rebuilt unit from Bob Ashlock (many thanks to Tonger for the great suggestion). I called Bob, super nice guy and he had one of his rebuilt units shipped out and in my hands in a few days. The M&W would have been cool, but I did not want to butcher my wiring harness. I installed Bob's rebuilt CDI (easy once you remove the intercooler) and the car started immediately. I have to still road test it but currently doing some other catch-up maintenance this weekend and then will have the car back on its feet by next week. Thanks all! Yasin
Going through something similar and great referral! Much appreciated
Some pictures to share!
That’s interesting- I had Bob redo mine maybe 10 years ago. Great after sale support. But mine doesn’t have that LED indicator your instructions mention, and it does still have the high pitched whistle.
Ken 1986 930 2016 R1200RS |
Ken - Bob must have reworked the CDI over the years to incl, the LED which is always "on" when the car is running and no longer has the high-pitched whine.
Regards, Yasin
