Are all years of the 930 considered Widowmakers?
Got my 1988 930 and I love sharing with folks its nickname was The Widowmaker. But as I read (ok, watch youtube) more about them, it seems the first 930s were "killers", but when they made the next group of them up to 1988-89, they were no longer considered as hard to drive, and maybe no longer had that moniker...?
Just want to tell the story accurately... and make sure my custom plates aren't way off the mark... lol Thanks all! http://forums.pelicanparts.com/uploa...1731531677.jpg |
It was in 1978 or 1979. Porsche was in a giant lawsuit over the 930 and lost if memory is correct. It could have put them out of business.
https://www.upi.com/Archives/1983/06/30/Too-dangerous-to-drive/4466425793600/
Dang, so it would probably be inaccurate to say my 1988 930 is part of the "Widowmaker" pack...
Isnt that kinda woke in today's world? I'm sure some widowers were also made :-)
In my opinion they all have a tendency to oversteer when suddenly off-throttle in tight turns. It's just physics with all that weight in the rear. Perhaps Porsche changed the steering geometry/alignment since the 70's cars to compensate somewhat. Braking before entering the turn, then staying on the gas through the turn does the trick pretty well. Perhaps the most dangerous part is hitting full boost at the turn apex and losing traction. I've never had an issue but then I don't drive as hard as some people might. |
i was always under the impression along with the oversteer. The original short stroke 3.0l with the 3ldz turbo had a lot to do with the nick name . They went from no boost to full boost in a split second . The newer versions have a more refined boost curve,
From what I remember the '78 and up 930 received rear suspension changes to reflect what the RSRs had in order to make them more stable. The brakes were upgraded as well and tire sizes changed in order to make them easier to drive. The earlier cars were more difficult to drive, but the moniker "Widowmaker" really is not fair. Put somebody who cannot drive into a high performance vehicle and you will end up with not so unexpected results. Do you know how many people got into accidents after buying Cobras in the 60's?
1978 and '79 930s came with 16X7 and 16X8 wheels, with 205/55 tires in the front and 225/50 in the back. These were the same tire sizes as on a contemporary Corvette, and my understanding is that these were the biggest tires available. The 76 and 77 models' wheels were even smaller: 15X7 and 15X8. Keep in mind that tire compounds and tire and tread design have come a long way in the past 45+ years.
Poor grip + rapid boost onset + steering input = unintended agricultural exploration |
The term used, "poisonous", in the original German doesn't have the same implication. For sports car enthusiasts, it's rather a compliment.
There were several threads that mentioned this lawsuit going back a while:
Lawsuits arriving from the 930 in the late 70's. In that thread, as well as a scan of contemporaneous newpaper reporting of the verdict, there was this quote from The ultimate Porsche Urban Legend thread: Quote:
As other have mentioned, the tire section size went up over the years, factory torsion bars got bigger/stiffer, and factory beefed up the sways. All of which moved the tendency from oversteer to understeer (although any 911-based car will do either, depending on how it's driven). And 70-80's tire technology, as others have pointed out, wasn't anything like the tires you can buy today. My '77, with 21/30 TBs/factory sways (and oversized 17" wheels with modern hi-perf summer rubber in substantially wider section than factory fitment) was quite horrific with the stock 3DLZ if you didn't manage weight transfer. Inducing oversteer into a curve and then hitting the brake pedal (most probably coming off the throttle, thus significant unloading of the rear - because I doubt they were left-foot braking like Walter Röhrl) sounds like a pretty substantial skills/instruction gap for any rear-engine car.. |
IMHO, the only real widowmakers were the '77 to '79 USA 930's.
Initially, the US cars were the only ones with air injection. Hans Mezger mentioned the effect that this had on the engine (SAE paper 780718): "During development of an emission control system for the US version of the 911 Turbo, it was observed that secondary air injection does effect boost and performance characteristic positively. In fig, 12 is shown that there is a distinct increase of boost pressure, torque and power output in the low speed range up to 3000 rpm. By injecting air into the exhaust manifold the temperature of the exhaust gas went up by 80 to 90 degrees centigrade." But there's more. In the end, they had to fit thermal reactors before the turbo to meet emissions. So you have the CIS continuously injecting fuel (with generous acceleration enrichment), the air injection providing the air to burn it, and a reactor to turn it into heat BEFORE THE TURBO. If you have ever driven an intact early car you know all that adds up to a heck of a wallop at lower engine speeds. You could find yourself overachieving in a tight turn, hop on the brakes, cause the rear tires to get up on their tippy toes, and then physics rewards your mistake with big oversteer. |
I think the "Widowmaker" label tends to get overstated when talking about the 930. The truth is, Porsche kept improving the platform through the years—bigger brakes, wider tires, revised suspension geometry—all of which helped tame some of the earlier handling quirks. That said, the basic nature of the car didn’t change: rear-engine, big turbo hit, and a chassis that demanded respect. Drivers who weren’t ready for the sudden boost or who carried too much speed into a corner could easily get caught out. In the right hands, though, the 930 is incredibly rewarding and not some uncontrollable monster. The nickname really reflects more about driver experience than the car itself.
