So, I’ve completed all the oil plumbing and GT3 style TT exhaust for my conversion… finally.
Anyway, when I crank the engine, oil was pissing out from the M14 seal/washer underneath banjo bolt.
I figured it must be a bad crush washer, so I replaced both M14 crush washers for the banjo bolt, and torqued it down to 25Nm.
Next attempt to crank the motor, oil now started pissing out from underneath the M18/M14 crankcase adapter.
Tomorrow I’ll replace the M18 crush washer and see how that goes.
Any ideas if I keep getting oil leaks at this junction?
I’m basically running a TurboKraft oil feed banjo bolt with the spring loaded check valve / ball bearing. I also have a AN4 T fitting off the AN4 banjo, with AN4 oil feed lines to my K16/16G hybrids.
Both turbos were pre-lubed with KLM pre-lube treatment to ensure they’re appropriately lubricated in a new install.
Here’s a pic of the fitting configuration, but now uses the Turbokraft Banjo bolt/check valve:
http://forums.pelicanparts.com/uploa...1738829943.jpg
