Clutch adjustment
Last week I bought a low mileage (19,000 mi ) 87 Turbo that had a recent engine out service and at that time replaced clutch and cable.
When I drove it it shifted fine but clutch engaged about 2 inches off the floor.
When I checked with a 1mm feeler gauge I couldn’t insert it. I then loosened it and did the whole procedure. At the bolt on the lever it was set at 1.2 mm. I then tightened the cable to 1 mm. Drove the car and it did make it engage closer maybe 1 1/2 off the floor. I should point out I put a screwdriver to hold the pedal up.
The car shifts fine but I rechecked that feeler gauge clearance I again could not insert it.
Is this normal? Even holding a flashlight there is no clearance.
Old 12-04-2024, 09:23 AM
I just put a new cable in mine a month ago. It should fully return to a 1mm gap when the clutch petal is released. I found it helpful after I made the initial adjustment to have someone press and release the clutch petal a few times while I was under the car watching the cable action. You should get pretty close to an inch of travel at the end of the cable.
Lee
1982 Porsche 930 - 3.4L, Motec M84 EFI, BB headers + intercooler, Ruf muffler, K27.2, Turbosmart BOV
Old 12-06-2024, 07:15 AM
I have noticed on mine that the omega spring sometimes doesn't quite pull the last mm out of the travel. There's no tension on it at all, and if I just touch it the last mm of travel snaps out.
idk maybe you and I both need a new omega spring?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 12-06-2024, 07:49 AM
Alan L's Avatar
Those springs are pretty strong. They don't fall over in tha last mm of travel. I have had the same issue at times. Something in the adjustment - maybe pedal end - worn bush.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 12-06-2024, 09:50 PM
I had the exact same issue when I had the 930 in my car, I just left it a lone and kept driving the car. when I removed the trans for the G50 transplant the clutch looked almost new, so as far as your clutch felt good just leave it alone and enjoy your 930.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 12-07-2024, 02:34 AM
stevie 77 930's Avatar
clutch take up is a function of the length of the cable adjustment at the clevis pin (pedal box) and the final adjustment at the clutch lever. You do need to maintain the 1mm clearance to make the bearing has no preload. My guess is the cable length was a bit different from prior cable when the new one was installed.
Not a tough of a job, but does require access to the pedal box and clevis pin (which is a pain) Center console removal is required along with center carpet. And then you need to get the under the car to adjust at the gearbox. Test and repeat until you get the feel you want.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 12-07-2024, 07:46 AM
