-   -   Accidentally turned crank backwards. What to check? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1170975-accidentally-turned-crank-backwards-what-check.html)
FirstDotLast 12-02-2024 10:40 AM
Hey all,
I was changing my clutch and when I went to install the pressure plate, the crank rotated a bit while tightening the bolts down (rotated clockwise while looking at the flywheel, which is counter-clockwise looking at engine from the fan side.). The crank turned a total of a few inches. I already rotated back to TDC and check distributor rotor position was pointing to the notch in the distributor.
Anything else to check to make sure I didn't do any damage? Again, this was all by hand and probably 30-40 degrees rotated. Thank you!
JJK78-951 12-02-2024 01:50 PM
Engines can spin both ways... I think you'll be fine~
gorskined 12-02-2024 02:41 PM
Just give it a rotation in the correct direction to put tension back on your chains before you start it.just to play it safe.
Alan L 12-06-2024 09:56 PM
Done it heaps of times.
No issue.
Alan
