-   -   930 efi power sorting (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1172646-930-efi-power-sorting.html)
quattrorunner 01-13-2025 06:51 AM
I want to list my mods then my problems in order to ask for help in safely raising my power level to what it should/could be.
Engine is Carrera/930 block from 84' Not split so original rods and rod bolts.
Cylinders are turbo 3.3 and pistons je forged 8.1/1. Fresh top-end with fresh Carrera heads.
ARP head studs I believe....
cams are Carrera currently.
Using Carrera intake and fueling rails but with built intercooler and 82lb injectors.
Turbo in Garret gt35r and fresh/good.
Headers are B&B with heat. Wastegate location is moved straight back but the outlet unchanged and not upgraded in my opinion just esthetically different.
I am using a 1 bar spring and that is working.
I have a custom exhaust with flow through muffler and an after 200cell cat. My system is valved but I have not opened the valve yet or on the dyno.
I am running electromotive tec200gt which is good. I can adjust whatever I need and it makes those adjustments. (I say this because I don't want people to get hung up on that unit as the source for my problems, I realize it's limitations but I'm not getting hung up from this unit yet.)
I have coil on plug and fresh plugs currently.
I have no boost leaks.
I'm running a short 930 trans no real complaints I guess.
934 clutch pressure plate and disk.
I did dyno this and with the 14psi I got a dismal 320hp on a dynojet.
I expected more but I did expect less than it should be as I do have a couple issues to sort out.
Issues:
Using a infrared thermometer I get 150-225* difference in temp of the headers from one bank to the other. my right side seems to have a different fuel pressure or some other reason for this variation.
Example 500f on left side and 325f on right idling. I'm not a mechanic though I can assemble one of these engines (I did not build this one) but I don't know what effects things like cam timing might do to cause this type of problem or what other thing might have this symptom.
My brain keeps coming back to timing of the cam one side to the next but I don't have reason for this thought.
The plugs were getting fouled with fuel before more tuning and it was always the right side bank and never the left......Something to think about.
Engine runs pretty well, I need to fine tune the tip-in and cold start a bit but otherwise it's smooth and nice.
I feel if I could sort this temp/fuel issue I could start raising boost and doing other things to get the moist of this engine combo.
My afr is safe on boost but the reference is after the muffler and a sampling of all sides obviously. My egt gets a bit hot on power but not alarmingly so. This is also sampling both sides. It does spike up to 1700f in extreme acceleration and goes right back down under normal driving to 1300-1450f at 75mph. Still I feel it's a bit hot.
I want to test my injectors they are new but i could swap them side to side...
What do you (those who have more knowledge than me) think about this?
Stephan Kasper? Chris Carrol?
Ideas?
http://forums.pelicanparts.com/uploa...1736783265.jpg
Mike80911 01-13-2025 09:06 AM
Sorry I don't have any helpful advice but just wanted to say beautiful car you did a great job with it.
quattrorunner 01-13-2025 09:14 AM
Thank you
dos531 01-13-2025 05:50 PM
Well it sounds like you already know one bank is running richer than the other. One thing to check would be the voltage to the injectors on each bank. If they're different voltages, the difference in latency could be enough to throw the fueling off significantly at idle.
David 01-14-2025 05:14 AM
I had a similar issue when I first built my 930 EFI engine. I checked everything to avoid rechecking the cam timing... it was the cam timing that was off left to right.
gsxrken 01-15-2025 04:02 AM
Agree with two things- very nice looking automobile and your cam timing is suspect. You’ve done enough troubleshooting and like David, you’re down to that. It’s doable in the car but depending on your shop situation it might be easier in the long run to drop it and do it on the floor.
What I would like to know from a Chris C is: what is the target exhaust temp? IOWs, one of the cams is different than the other, but which is “better”? Don’t assume the colder one is. Camgrinder gave me a range to set my SC grind cams when I assembled my engine during Covid… I don’t think there’s a wrong answer in the range per se but they should both be set equal to the other.
spuggy 01-15-2025 02:47 PM
Definitely think they should be set the same.
As far as to where they should be set in the range, I had my SC cams set "retarded" (eg timed towards the late-opening end of spec) way back when (2006?). Someone said at one time that this would help reduce blow-through due to timing overlap under boost and help spool.
For a subsequent round of work a year or two later, shop (different one) said they set the cams to "more normal" timing figures - and that they thought I'd much prefer it.
They were right; drove considerably better better off-boost (better yet with extra advance), much more responsive. No power loss noticeable on-boost.
For my money, time the cams as advanced as you can get within spec on both sides.
TurboKraft 01-16-2025 11:18 AM
Nice-looking build!
A few questions, please:
Where are you measuring EGTs?
And are you using them as an input to the ECU?
Finally, are you running closed-loop, or open?
quattrorunner 01-20-2025 08:08 AM
My engine was built by a good guy and I believe he knew what he was doing. The cam timing portion of the build is pretty hard to get numbers wrong as it's an obvious attempt to time if I remember but this thought has kept me guessing.
My efi doesn't use egt as a reference. I take the temp reading from the bung area under and before the turbo.
I believe the operation for the most part is open loop but I am not expert or up to the know on that..... Thanks for all the input.
Engine has about 6000miles if that. I have great leak downs and unsure on compression as I think my compression tester is dumb. Car runs smooth.
quattrorunner 01-20-2025 08:24 AM
I guess I should say the 320hp is through a cat......will a cat remove 50hp?!
fourblades 01-20-2025 08:41 AM
I would figure out what is causing this before worrying about power output:
If one bank is running lean, then you could cause major engine damage.
Try taking the temperature of each stub pipe at idle at the same distance to the exhaust port and see if maybe one cylinder is not firing at idle?
I've had pins back out on the COP plugs when changing plugs and cause a cylinder to not fire all the time.
John
flightlead404 01-20-2025 01:53 PM
Typically EGTs are taken within a very short distance of the exhaust valve. I would say 4" would be the max distance, often shorter. The exhaust has a long time to cool before it gets to where you're measuring it if I understand your description.
quattrorunner 01-20-2025 03:48 PM
True
bleucamaro 01-28-2025 12:20 PM
With info provided, I'd guess that you're on the right path suspecting a fuel pressure delta between banks.
Asking the dumb question: Are all the injectors the same, and are they all firing the same (no tunings applied in the ECU)?
Not as dumb questions: How is your fuel system plumbed? - have a diagram that's sharable?
Using a return system, or dead-headed? Are the banks in serial or parallel? Where's the fuel pressure regulator? Are you using 90° fittings (not radiused)?
What I'm getting at - there's a lot of ways you can have different fuel pressure at different banks and it might be worth investigating.
TurboKraft 01-28-2025 12:50 PM
I had an extensive reply written out but it didn't post after all.
Give us a call, way faster than re-typing.
David 01-31-2025 05:18 AM
When you say one side plugs fouled and the other not, is the plug color noticeably different? Mine were drastically different like white plugs on one bank and dark brown on the other bank.
quattrorunner 01-31-2025 07:16 AM
http://forums.pelicanparts.com/uploa...1738340183.jpg
quattrorunner 01-31-2025 07:17 AM
One of my plugs was still stuck
quattrorunner 04-23-2025 08:49 AM
I had a cam timing issue that I thing was caused by an accident.
My no1 side was timed 1.9mm at z and no 4 side was showing .16mm at z so I assume it was off by maybe a tooth or two I don't know but it was off for sure.
So....it's all back together same setup other than a new flywheel that is a couple lbs heavier which helps on the commute lol.
I have basically had to retune it. This is where I falter. My "new tune" that I thought I was so crafty and smart to do was as mess when I drove it, 10 afr or worse on cruise. So I reverted back to an older known tune but for an engine that was not right look above for why. It does run better and sounds much smoother. I'm happy but since I pulled a lot of timing out because I read and hear that 30-35 degrees is a lot I don't want to damage the engine but it's just not making the power. Probably less than 300 or so. I guess I can keep messing with it but I don't have knock sensors yet and im old and deff. Any pointers? I'd like to see more ignition maps and stuff so I can compare and make adjustments.
LeeS930 04-24-2025 04:08 AM
Here is my base ignition map - nothing much changes from 4K+ in my map
I do some other minor compensations for high intake air temp, high engine temp, and cold engine temp. Engine is designed to run on super unleaded with a max boost of 0.9 bar.
The timing hole just above idle helps keep things smooth and consistent with or without the AC running.
I found having an advance in the mid 30's helped significantly under low load "cruise" conditions. My target AFR is ~0.97-0.98 steady state cruise and 0.8 at full boost.
http://forums.pelicanparts.com/uploa...1745495847.jpg
fourblades 04-25-2025 03:03 AM
Have you checked your timing with a good timing light?
Maybe your timing is more retarded than you think?
John
gsxrken 04-25-2025 06:23 AM
I see you’re a 6 hour drive from the wizard of Mesa, AZ. The right tune is so critical to civil and safe power… if I was in your shoes, I know what I would do, assuming they’re familiar with your electromotive CPU. Rob a 7/11 or something if you have to.
quattrorunner 04-27-2025 08:20 AM
Thanks for this map. I will actually make a tune with your timing values and see what it does. But I can’t imagine it will even run on its own. I wonder if the fact I still haven’t set up an idle stabilizer yet causes some of my issues.
Fourblades no I have not physically looked at timing with a light. So far I have only trusted the quality parts and display on my laptop. I think maybe I’ll try it today.
Thanks guys.
quattrorunner 04-27-2025 08:28 AM
Ya I know but honestly this system is working really well. It might not be as easy I don’t know because I’ve never used anything else but it is effective and does what it is asked. It uses good sensors and inputs. I trust it I just would love to have someone more Knowledgeable tune this and run it.
I just got back from air and water in Newport california last night. The tune was great. I did some tuning on the way down on the road it was late 12-5am so not many cars on the road.
Basically re everted to the last tune from my Dyno test and made some highway adjustments. Ran well and kept afr’s and egt’s in the safe range. Still could use more tuning for tip-in and sharpness but faster on boost.
I want to have another Dyno tune and see where I am. But right now I need to rest. That trip was nuts for other reasons.
mikedsilva 04-28-2025 03:23 AM
Sounds like you're well on the way to having this sorted : cool.
My timing map is similar to LeeS930's. I'm an amateur and my 3.0SC turbo puts down 296hp to wheels, with 0.5Bar
fourblades 04-29-2025 03:11 AM
Timing on EFI systems should be checked when new or changes are made to be sure the timing wheel/sensor positioning is returning an accurate crank angle. Being off +/-5 degrees makes a big difference to power and engine safety. TDC Setup fields on the "advanced parameters" page can be used to adjust this on Electromotive.
quattrorunner 04-29-2025 07:23 AM
Good point, I'll certainly do that. Currently trying to sort out a clutch issue. Good grief.
