Twin Turbo engine oil?
Hey guys,
What oil are you all using?
I’m looking to use Penrite 10W60 (fully synthetic) in my TT’d ‘89 Carrera motor.
Thoughts?
Old 01-25-2025, 02:42 PM
Originally Posted by 911TT33 View Post
Hey guys,
Thoughts?
I use this after consulting with the owner of High Performance Lubricants.
https://www.advlubrication.com/collections/automotive-lubricants/products/bad-ass-racing-oil?variant=31358989893655
1987 930 M505 Cabriolet - Original owner
Mahle 3.4L, K27-7200 QS, Port matched heads, 993 Super Sport cams, Pauter Machine billet forged 4340 connecting rods, 360 lb/in springs, TiAL waste gate, TurboKraft intercooler, Turbosmart PlumBack Uni BOV, Numeric shifter, 993 Cabriolet Top, Rarlyl8 Center exit exhaust
Old 01-29-2025, 10:01 PM
Originally Posted by SLNT930 View Post
OK, so experts also recommend 10W60 synthetic. Sweet. I’m on the right track 😎
Old 01-31-2025, 03:36 AM
Nooooooooo! Not another oil thread.
Just use the search feature... PLEASE
Derrick
Old 01-31-2025, 10:01 AM
Banned
TurboKraft used Driven DT50 15-50 for my rebuild, and was *so impressed* with the "gooeyness" of the oil, waaaaaaaay beyond anything I've ever experienced - like nothing I've seen before.
Spendy, but I'm stickin with it. HTH
Old 02-01-2025, 07:15 AM
mark houghton's Avatar
I've been using 20/50 VR1 from Valvoline for years, mostly because it has high zinc ZDDP...and because it's readily available. And I'm soooo impressed with it (meaning my motor has yet to blow up). The true measure of success.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-01-2025, 10:08 AM
Grappler
Rodsrsr's Avatar
Same here on the Valvoline 20/50 VR1 and no more flattened cams!
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 02-05-2025, 10:48 AM
What convinced me on Valvoline VR-1 was how well it holds up in heat. The flashpoint was as good or better than some synthetics.
I’m a firm believer that driving home at a slow pace and idle for 30 seconds will help prevent the coking issue
Old 02-05-2025, 12:36 PM
Interesting on the 20W/50 VR1.
With the 10W60 I’m noticing leaks I never had before! 😡
Old 02-06-2025, 12:32 AM
Motul 300V 15W50 LeMans
Old 02-06-2025, 10:27 AM
No big surprise when switching to synthetic oil. It has a way of finding leak points. I stick with dinosaur squeezin's, not concerned with "coking up" my turbo since I don't run it that hard for extended periods. 20/50 works good for my semi-arid climate and high zinc is important
Old 02-06-2025, 05:58 PM
Good to know. Might do the same actually.
I seem to be leaking oil from under the M18/M14 engine case adapter where I’m tapping the oil feed from for my TTs. 🙄
Old 02-06-2025, 08:18 PM
