Asking ChatGPT For Build Plan
Hey folks,
Im in the process of planning out a build for either turbocharged 3.0 or 3.2. So for poops and haha I asked ChatGPT create a build plan for converting a 3.0 motor to EFI and turbocharging it. Below is the response I received. Pretty good start if I may say so, but certainly would not use it. Nevertheless its interesting the plan it came up with. Anyway thought I would share. Converting a 1982 Porsche 911 SC (3.0L) engine to electronic fuel injection (EFI) and adding a turbocharger is an excellent way to significantly increase performance and tuning flexibility. Below is a detailed build plan for the EFI conversion and turbocharger installation. Build Overview Goals Replace the CIS fuel system with a modern EFI system Turbocharge the 3.0L flat-six with safe boost levels (~6-10 psi) Optimize fueling, ignition, and cooling for reliability Maintain good drivability and durability 1. Component Selection Standalone ECU Recommended: Megasquirt MS3 Pro, AEM Infinity, Haltech Elite 1500, or Motec M130 Features needed: Boost control, wideband O2, sequential injection, coil-on-plug ignition Turbo System Turbocharger: BorgWarner EFR 6758, Garrett GT3071R, or Precision 6262 Wastegate: Tial 38mm or 44mm external wastegate (spring set for 6-10 psi) Blow-off valve: Tial, HKS SSQV, or Turbosmart Intercooler: Custom air-to-air unit (mounted in rear decklid) or air-to-water intercooler Exhaust manifold: Custom turbo headers (Bisimoto, RarlyL8, or custom fabricated) Oil system: Turbo oil feed line (from engine case) & scavenge pump (if needed) 2. Fuel System Upgrade EFI Injectors: Bosch EV14 50-60 lb/hr (supports ~400-500hp) Fuel Rails: PMO, Clewett, or custom fuel rails Fuel Pressure Regulator: Adjustable 3.5-4 bar Fuel Pump: Bosch 044 or Walbro 450 LPH AN Fuel Lines: High-pressure lines with return setup 3. Ignition System Upgrade Coil-on-Plug (COP) or Wasted Spark Coil Packs (Bosch or AEM) Crank Position Sensor: 36-1 trigger wheel on crank pulley Cam Position Sensor: (Optional for sequential injection) ECU-Controlled Timing: Retard under boost for safe operation 4. Intake System & Sensors Intake Plenum: Stock or upgraded 3.2L Carrera intake manifold Throttle Body: 3.2L Carrera or custom unit with TPS MAP Sensor: ECU-integrated (handles boost pressure) IAT Sensor: Placed post-intercooler 5. Exhaust & Turbo Piping Exhaust Manifold: Custom turbo headers Downpipe: 3-inch stainless steel (heat-wrapped for thermal control) Wastegate Dump Tube: Recirculated or vented to atmosphere 6. Cooling System Intercooler: Rear decklid-mounted air-to-air or water-to-air Oil Cooling: Front-mount oil cooler (Setrab or Mocal) 7. Drivetrain & Transmission Considerations Clutch Upgrade: Sachs or Spec Stage 2/3 clutch Transmission Strengthening: Optional WEVO upgrades for 915 gearbox 8. Installation Process A. Remove Old Components 1. Remove CIS fuel injection system (fuel distributor, WUR, airbox) 2. Remove stock exhaust & heat exchangers 3. Remove distributor (if converting to COP or wasted spark) B. Install Turbo System 1. Mount turbo headers & turbocharger 2. Install oil feed & return lines 3. Install intercooler & charge piping 4. Mount wastegate & blow-off valve C. Install EFI Components 1. Install fuel injectors, fuel rails, and high-pressure fuel pump 2. Install crank position sensor & 36-1 trigger wheel 3. Wire ECU, sensors, and ignition system 4. Install MAP sensor & IAT sensor D. Tune & Optimize 1. Base Map Setup: Configure fuel & ignition tables for safe startup Set boost controller to wastegate spring pressure (~6 psi) 2. Initial Startup & Idle Tuning: Verify fuel pressure, injector duty cycles, and ignition timing Adjust idle AFR (14.7:1 at idle, 12.0:1 under boost) 3. Dyno Tuning: Adjust boost levels, ignition timing, and AFRs for safe power Set boost cut, rev limiter, and knock control 4. Road Testing & Data Logging 9. Expected Performance & Reliability Low Boost (~6-8 psi): ~300-350 HP Higher Boost (~10 psi with supporting mods): ~400-450 HP Considerations: Reinforce head studs to avoid head-lifting Monitor AFRs, EGTs, and boost pressure for safety Regular oil changes & turbo maintenance Final Notes Boost target: Start with 6-8 psi for reliability, increase only with proper tuning Intercooling is essential for charge temp control Keep a conservative tune (rich AFR & retarded timing) to avoid detonation Upgrade brakes & suspension if making over 350 HP Would you like recommendations for specific EFI conversion kits, turbo kits, or tuning software? |
Holy s...t. That is scary.
Alan |
Agreed! Scary yet pretty damn cool. I mean it’s not that much off.
I agree lol.
Fascinating, and all done in probably seconds. Imagine the time it would take you searching the web to put all that together. AI isn't smart, it's just a very refined search engine in my view.
| All times are GMT -8. The time now is 01:41 AM. |
