LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Alan L's Avatar
I have thought about that too, but not come up with a solution. The reason being we boost between 0.5-1 bar. The smoke test machine I have runs at 3 psi. But a leak under boost could always be an issue. I have had the IC lifting.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-30-2025, 12:28 AM
mark houghton's Avatar
Alan
Years ago I fabricated my usual MacGyver rendition smoke machine with a quart jar, a piece of nichrome wire wrapped around an oil soaked rag and powered by a battery charger, and air lines fitted to the lid fed off my air compressor. Dial in whatever pressure I wanted.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 05-30-2025, 05:17 AM
Banned
Okiikee911s's Avatar
Anyone here ever tried a smoke test?
Old 06-08-2025, 06:18 AM
Bucketlist's Avatar
A couple of years ago when I was chasing inconsistent air fuel readings and poor running problems I bought a smoke machine off ebay. this was a last resort since I felt I had tried everything else. I ran several tests leading to a surprising diagnosis which I thought I had already cured, a split o ring in my up pipe from the turbo. I knew this was a problem area and had recently (carefully) replaced them. I couldn't find this leak any other way without smoke.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 06-09-2025, 02:23 AM
