-   -   🌀 Quick Boost Spike Fix on My 930 — Simple Solution (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1180634-quick-boost-spike-fix-my-930-simple-solution.html)
audiblypry 07-24-2025 12:28 PM
Was getting random boost spikes on my ‘86 930 — thought it was the WG spring or overboost switch.
Turned out to be a cracked vacuum line to the wastegate! Replaced it with high-temp silicone hose, and now boost holds steady at 0.8 bar.
Old school fix, but worth checking if you’re chasing boost weirdness.
Anyone else dealt with this?
908/930 07-24-2025 01:19 PM
Just checking that the silicone hose you used is a reinforced type? That hose also required to hold pressure.
mark houghton 07-24-2025 04:22 PM
Good deal! But to be clear, the hose to the WG is not under vacuum...it's pressure. And the over-boost switch/sensor will not cause an over-boost scenario should if fail. Designed to cut off your fuel pumps in the event of over boosting due to a faulty wastegate (or plumbing to it as you have found).
