Tire Recommendations, 1979 930, Stock Fuchs
I’ve searched through previous info, but it is all pretty old.
Stock sizes are front 205/55 R 16, and rear 225/50 R 16. Just wondering what folks are running these days with currently available tires, if you are running spacers, or perhaps a bigger tire to fill in some of the space. My car is Euro ride height so just want to make sure whatever I get will not rub. Also, it is more of a driver than a show car, so I am leaning more toward a modern compound versus period-correct tread pattern, but open to ideas. Thank you. |
Im very happy with the re71rs. ‘79 930 with same wheels as you though my car is lower. Just… dont even think about driving them in snow.
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1178650-930-tires-2025-a.html |
I think the RE71RS is still king these days. A052 is another great option.
P7 for the period look.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Thanks!
Looks like the RE71RS are not available in the larger 245/45-16 size for the rears, only the stock 225/50-16 size. Any reason I shouldn't go with the larger size to get a bit more rubber on the ground, as well as fill out a bit of the empty space? Thoughts on spacers? |
For performance its not simple: https://grassrootsmotorsports.com/articles/wheel-width-is-wider-always-better/ https://www.roadandtrack.com/car-culture/buying-maintenance/a21776425/wider-tires-more-grip/ These cars already have too much understeer. Why do you need a bigger back tire? I vote spend your money to get your suspension ‘did’ so its nice to drive - and lower it more.
Conti DWS
For a 930, which is known for its visceral and raw driving character (including its infamous turbo lag and pendulum-like weight shift), many owners and experts prefer a tire that matches the car's original character rather than overwhelming it with ultimate modern grip.
I mean, you might as well wax poetic about the benefits of thermal reactors. |
They kind of has a point if car still has original rubber bushings and stock undersized sway and torsion bars. Even old tires can really twist up the stock suspension.
My point is that there's no reason to wax poetic over things like turbo lag and lack of grip. These are negatives, not positives, and can be pretty easily rectified with modern bolt-on solutions.
BTW, your car looks killer, zakthor! |
On our 912, I run **175/70s on 15x6 wheels**. On my Carrera, I’m running **225/45s on 16x8s** up front and **245/45s on 16x9s** in the rear. For SCs and Carreras, I usually recommend sticking with the factory tire sizes but upgrading the wheels from **6/7s to 7/8s** for the best combination of grip and handling.
