cis air box gasket and smoke test
Its that time of the year again here in the North East . Time to address a few gremlins .
i have a newly rebuilt 76 3.0l row turbo with an ic . The motor runs great and is a blast to drive. But runs rich in boost. When not in boost the afr is spot on but once i go into boost the afr starts to drop, after a second or two I'm into the mid 10s AFR. The longer in boost the lower the afr will go ( i am not allowing boost dump to add more fuel . The rpm hold out set to 7k and the vacuum line removed and plugged on the fully adjustable wur. .( afr mid 10s without the boost fuel dump working ) i realize all fingers point to a air leak on the pressure side of the turbo. i plan on doing a thorough smoke test . I would love some direction on how to do this. the dos and don'ts. . how to make a diy smoke tester ? best place to connect is there any way to get a good pressure in the intake manifold, possibly a crank position where all the valves are closed ? second question is how tight should my cis air box screws be the ones that hold the upper and lower half together with the little springs .. and what is the purpose of the springs ? should the gasket have any type of sealant like (curil t) of just the plain paper gasket? im assuming if my gasket was leaking that would cause a lean issue. Thanks Regards Ned
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body Last edited by gorskined; 11-26-2025 at 09:57 AM.. |
A smoke test is the gold standard for finding these leaks. |
