CR of most Turbocharged cars?
Ok in an effort to kick start this forum my question is.
What is found to be most desirable for a low boost turbo application CR?
I see hot 930 motors run at 8-1. some the 962 ran higher then that. 935 were like 6.5-1 so where is the happy medium and why??
I was 9.3-1 and now shooting for 8-1.. Any thoughts?/
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 10-30-2006, 04:30 AM
AFJuvat's Avatar
IMO. 7:1 - 7.5:1 with 0.9 - 1.0 bar of boost is about ideal for a street turbo. That strikes the balance between really usable power (on the street) and engine longevity, further, you can dial in the correct fuel and timing without significant modifications (other than euro CIS) Much higher than that and you are committed to an engine with a shorter lifespan.
8:1 or higher usually requires some mixture adjustment as well as a timing adjustment. Some sort of crank-fire ignition system where the timing is much more adjustable is recommended.
The race cars: 935, 962, etc are not really good benchmarks. They ran much higher boost, much higher octane fuel, and the engines needed to last only one race before overhaul.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-30-2006, 04:50 AM
keep in mind I am using MS and will be using EDIS controlled by MSII next go around and boosting .5 bar
Ben
Old 10-30-2006, 04:53 AM
resident samsquamch
sand_man's Avatar
FWIW, my 3.4L running .8 BAR of boost has a CR of 7.3:1
-jeff
Old 10-30-2006, 06:03 AM
David's Avatar
I think 7.5 to 8 is opitimum for an air cooled EFI car that will run at 1 bar.
2014 Cayman S
2011 Cayenne Turbo
Old 10-30-2006, 06:16 AM
wow so I could run a lot higher boost then I was intending with my 8-1 setup
Ben
Old 10-30-2006, 06:26 AM
Crotchety Old Bastard
RarlyL8's Avatar
If I remeber correctly, each pound of boost adds something like 0.3 points to the effective compression ratio.
So if you start with say 7.0:1 (stock 930) and boost it 1.0 bar you end up with an effective comression ratio of 11.2:1 which is at the limit given the combustion technology of the 930 engine.
This may seem a bit simplistic, that the relationship is liear, but I would use that mathmatical logic if building an engine myself.
Corky Bell goes into this very well in his book Maximum Boost.
Old 10-30-2006, 09:18 AM
Originally posted by RarlyL8
... given the combustion technology of the 930 engine.
Does twin plugging help this?
Old 10-30-2006, 09:31 AM
David's Avatar
From Graham Bell's book:
This is probably for a watercooled engine, but I figure our engines are pretty robust so it should be reasonable for our's.
EDIT: that's weird, are you all seeing a picture or a link above? I see a link.
2014 Cayman S
2011 Cayenne Turbo
Old 10-30-2006, 11:13 AM
thats pretty cool really
Ben
Old 10-30-2006, 11:52 AM
WydRyd's Avatar
How about Juan's and Mike's EFI'd Carrera's that run 22psi on pump fuel at the normal 7.0:1 C/R?
I suspect that EFI and full bay intercooler conversions bumps up that "limit of 1.0bar" quite substantially
And yes, twin plugging improves the combustion efficiency as well, providing even more safety margin, or allowing even more boost, since flame travel is halved
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 10-31-2006, 01:52 PM
Me like track days
Craig 930 RS's Avatar
This guy who was the chief mechanic on this:
Is a huge fan of 7.5 CR and higher boost vs. 8.0 and lower boost
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-01-2006, 11:25 AM
WydRyd's Avatar
Yup, I vote for lower C/R and more boost, than higher C/R and lower boost
Mike Rombotis was able to run his TT'd Carrera at mid 600HP @ 22psi on pump grade fuel, on a mediocre tune
Merv
'89 911 Turbo Cab
Old 11-01-2006, 04:24 PM
beepbeep's Avatar
My company car has C/R of 9.35:1 and runs up to 1.3 bar of boost, straight out of factory It's a SAAB.
You can run heaps of boost even on hi-comp engine as long as you retard the ignition enough. You won't be making any power though but it's seems that most important thing nowadays is to boost as much as possible, not to make power
Imagine car A and car B, same C/R, same turbocharger (let's say it uses K27), but different boost.
Car A boosts something like 0.7 bar and has ignition mapped for optimal BMEP troughout range (BMEP is all that matters). It will have good torque, good off-boost response, it will be frugal with fuel and intercooler/turbo won't need to work as hard as turbo efficiency will be on-spot and density-ratio would be low.
Car B runs 1.3 of boost. In order to allow that kind of boost ignition has to be dialed back. Turbo will be out of it's efficiencyy range, pumping hot air around. Intercooler will need to work harder and you will be feeding hot air into engine, further aleviating need for less ignition advance. You will need to pump more fuel into it to compensate all that air and it won't neary make as much power as 1.3 bar of boost indicate, use lot's of fuel and will fail more often.
It's always a trade-off. If you want lot's of power trough lot's of boost you need to build it with low C/R and turbo that is made to work efficiently with high pressure ratios. Such engine will be laggy.
Thank you for your time,
Old 11-02-2006, 12:04 AM
thats is what some th HP drag racers are doing these days for optimal performance and effeincy
Ben
Old 11-02-2006, 03:05 AM
