Me like track days
Craig 930 RS's Avatar
Question Stephen aka Porsche PHD - Your take on the boost/CR balance?
Generally speaking & for the benefit of everyone:
For a fully optimized and tuned CIS system (Adj WUR, IA fuel head, twin plug, K27 HF turbo, 965 IC, Tail WG, AFRs virtually level from top to bottom/12:1. Runs about 10 track days per year.
What would you prefer to see - lower CRs and 'higher boost', or vice-versa? Could you elaborate?
My own data point: I am currently at 7.5:1 with .9 bar boost.
Intended as an open discussion with Stephen's input as to actual experience. Thanks in advance!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-05-2006, 09:47 AM
WydRyd's Avatar
IMO, if you're going to be tracking the car, where it sees high loads and sustained max boost levels, I think you're safer sticking with low C/R and moderate boost levels.
I'm sure Stephen will chime in with a more technical and scientific response though
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-05-2006, 07:18 PM
I wanted a bit higher CR so that off boost it was very streetable and I don't intand on tracking the car so this was what I went with.. A couple of folks using the BAE kits on their SCs with low boost and love it because it is very linear acceleration.. But for a monster turbo motor less CR is better and safer
it all depends on street or track applications
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-07-2006, 06:11 AM
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=330044178307
look at the CR of this car
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-07-2006, 06:16 AM
mic mic is offline
mic's Avatar
Send a message via Yahoo to mic
I am trying out 9:1 CR on a 3.8ltr TT motor that is in the works. The plan is to limit boost to 0.7 bar - no lag, quick spool. The hope that this is a nice streetable tyre burner with quick acceleration. I am not planning to race the car, so i dont need high end HP. (where i drive i rarely get the car in 5th gear). But, if i decide to track the car (DE etc), i intend to run 100octane and crank the boost a couple of notches.
This was all under the recommendation of my builder who has build porsche race cars for several teams (incl. some that raced at daytona).
Mike.
89 930 Turbo Cab.(soon for sale)
Old 11-07-2006, 07:10 AM
I am running a 1986 3.3 turbo with 8.0 to 1 cr euro fuel system powerhaus stage 2 tubo kolken ic 964 cams and extensive head work completed the engine about 2 years ago and the power gained in the low end was unbelievable. I have no detonation problems and has been worry free. Also running with 1.0 bar spring so it can be done with a lot of tuning.
1986 Porsche 930 Strosek
Old 11-09-2006, 03:47 PM
