Install425's Avatar
Exhaust Mod E-cutout
When I first got my exhaust it only had a single out pipe.
But my bumper had dual cut outs ( 965 style) so I had a fake pipe welded on.
Then after a while I thought it be nice to open up the fake side. Well I did and it was nice but to loud sometimes. Like driving through the neighborhood at night. So I found this valve called a E-CUTOUT ( http://www.dmhperformance.com/ecutout.htm ). This is the coolest thing ever.
Rob,
88 911 Turbo
Old 11-05-2006, 05:41 AM
wow thats funny...
a month or two ago i posted on the 911 tech forum about fabricating something like that for my twin exhaust. So at the flick of a switch i could have it noisy or quiet.
People however said that it'd mess with the mixture... how do u find it?
_____________________
'73 RSR Interpretation
Old 11-05-2006, 03:06 PM
Install425's Avatar
Seems to run about the same open or shut. Pops more with it open on decelerating. I think it just that I can hear it more. Sounds and works really good.
Rob,
88 911 Turbo
Old 11-05-2006, 04:25 PM
Crotchety Old Bastard
RarlyL8's Avatar
Can you wire it so that it opens automatically on boost?
Old 11-05-2006, 06:48 PM
Well, by adding the second pipe on the right, you have in effect shortened the muffler. This results in a leaner mixture, which could be causing the popping on decel.
Well... just wait for someone who know's what they're talking about to reply. Maybe should've posted in the 911 Technical Forum.
Adam
Old 11-05-2006, 06:58 PM
Install425's Avatar
One thing that is strange, with the valve open exhaust coming out of the right side seems to be cold and left side is always hot. I'm a little confused with this. Anyone have a explanation.
Rob,
88 911 Turbo
Old 11-06-2006, 03:54 AM
wow very cool maybe we should offer that as an option on our mufflers
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 11-06-2006, 06:15 AM
930turbo's Avatar
Very nicely done. Clean install!
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 11-07-2006, 04:29 PM
BoxxerSix's Avatar
There is a company called ATP (www.vwturbo.com) that sells a similar exhaust bypass valve that is controlled via boost. They call it their VES valve Works very well for what it is. Hook up a simple vacuum shutoff valve if you want to disable it at anytime....or just retrofit the above model with a wastegate actuator...or just adapt an adjustable hobbs boost switch to the above model. Lots of boost-controlled options
Adam Hennessy
Old 11-07-2006, 06:23 PM
David's Avatar
I would guess it's the pressure drop across the valve that makes it cooler.
Pretty neat valve though.
When you go EFI, maybe you can add some fuel when the valve is open.
2014 Cayman S
2011 Cayenne Turbo
Old 11-08-2006, 04:38 AM
#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
The electric controlled valve is WAY Cool! I can see spending the $ for that item on my muffler!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 11-12-2006, 04:37 PM
