Camshaft holding plate problem
We are putting together my 3.4 engine with Mahle p&c's we have the cylinder heads and cam housings mounted. We are having a problem with the chain housings. They are too long and we canít put the camshaft holding plate on due to the increased cylinder height. What is the common remedy? Shaving the chain housing or grinding the opening of the holding plate to make it slightly oblong?
Old 11-11-2006, 08:29 AM
Photo:
Old 11-11-2006, 01:05 PM
adomakin's Avatar
shave the housings.
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 11-12-2006, 05:49 AM
Remember
The Turk's Avatar
Did you measure the deck height of the pistons to the top of the cylinders when you assembled the motor ?
If the deck height was correct your heads must have had a lot of material removed for the housings to be that far off.
If both surfaces are good you could probably eliminate the gasket with a good sealant, Curil T would do the trick.
Good Luck.
Gary
1975 911S G50 3.5 Twin Turbo
Old 11-16-2006, 08:21 AM
Turns out the twin plug heads that I bought were machined down 1 mm (assume to eliminate some pitting) so we've machined the chain housing 1mm to compensate.
Old 11-16-2006, 08:59 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
