WydRyd's Avatar
Question BERU ignition leads?
Anyone here using Beru ignition leads on their high HP turbos?
I'm thinking of perhaps having a 964/993 set made from these for my twin plug conversion, running dual Crane HI-6 sysems.
I don't really want to splurge the $$$ for Magnecors
Are BERU's any good?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-22-2006, 06:44 PM
Jeff Alton's Avatar
You can also look to Kingsbourne (sp). They should have all the parts you need. So should JB racing or maybe Henry at Supertech as well.
Cheers
jeff@turn3autosport.com
997 S 4.0, Boxster 2.7 Race Car, Cayman S 3.8, 958 Cayenne TT, VW GTI 2.1 TSI, Mini Cooper S JCW, Cannondale Supersix EVO SRAM RED E-tap, Cannondale Slice SRAM RED E-tap, Giant Roam Hardtail- to ride with the wife.
Old 11-22-2006, 09:06 PM
WydRyd's Avatar
How much is a set for the 964/993 dizzy?
Merv
'89 911 Turbo Cab
Old 11-23-2006, 01:37 PM
Nine9six's Avatar
Aren't Beru's OEM? If they last 20-25yrs, would that not put them in at least a "good" category?
To me, they are a great set of extremely reliable set off wires.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-24-2006, 02:48 PM
Gumba11's Avatar
I prefer Magnecor KV85's but I have heard nothing but good about Beru stuff as well!
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 12-02-2006, 12:45 AM
rotorhead's Avatar
Ignition leads:
Beru connectors go on solid core leads, the leads have no resistance and the beru connectors have resistance built in. This way each lead displays the same impedance regardless of length. Technically a superior setup.
Magnecore / Spiral wound / Supression leads use RF supression built into the lead and not the connector. This is a cheaper alternative but the resitance / impedance varies with the length of the lead.
Some aftermarket CDI setups like the MSD specify NOT to use solid core ignition leads (ala Beru) as it will void the warranty.
A great company in Aus to order custom ignition leads from is Queensland Ignition Leads (07) 3886 6700 MQileads@aol.com, they are doing a custom set of 8.8mm spiral wound supression leads for my 930 EFI mod for only $80AUD ($60USD). I am doing a 3 coil pack wasted spark EDIS on a EMS Stinger ECU.
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 12-15-2006, 05:00 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
