Automotive Monomaniac
Craig,
What's the little area on the bottom right for? Intake snorkel? - Mike
2012 - Porsche Boxster Spyder 6MT / 2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 2018 - Volkswagen GTI 6MT |
Me like track days
Bingeaux......
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Smart.
Me like track days
I just bought a riveting setup & I have sheet aluminum.
In a few weeks or so, I'll try a cool air box fed from the tail inlet - with a very small open portion on the bottom in case water gets in the box. Not gonna be easy - it is tight in there! ![]() Inlet temps are 14 degrees above ambient, so this ought to get inlets very close to ambient - (Sorry for the temp thread hijack)
Guys, is this the stuff I should look at using for the IC shroud?
Thermotec Pipe Insulation I think the "QUick Seal" product has the adhesive centre.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
Me like track days
Make sure it is the stuff that is 'more rubber than foam' regarding the properties - it is more pliable than the cell foam stuff. Heat resistant is a must too. My opinion -
Thanks Craig.
A fellow Pelacanite
The rubbery type in the UK is known as "Armaflex".
http://www.buildingdesign.co.uk/mech/armacell/armacell.htm
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Me like track days
FWIW, the rubbery stuff tends to 'stick' on a warm IC and pull off the metal shrouding - just kinda be aware of this when you assemble and design your setup.
I haven't had any problems with the sticky stuff yet. That is the correct polyfoam Merv. What I did was to cut one piece about four inches too long and then spread the slit open and lightly stick it onto the top and side of the IC. Then cut another piece on a connecting side that is also too long. Since the pieces are round and not quite at a 90 angle you must eyeball the miter or corner cut. Cut one piece at a 45 degree end and then cut the adjoining piece and trial fit it to the other 45 deg. cut. Work your way around the IC and when you are done use some black weather strip glue on each corner and the put tape around the whole thing until it sets up. The original glue on the insulation is not meant to hold against metal so you will have to decide what type of glue to use. I used the same weather stripping glue. Now when you close the lid there is a tight seal with the IC and no air goes around the IC. Please note, this is not a concours mod. It works well and when it needs to be replaced due to damage or werar, it will cost you another $10! Not many P-car mods for that kind of money.
911rudy |
Thanks for the detailed explanation, Rudy.
I'm not a concours junky, so I don't care if it aint pretty. As long as it's functional, improves cooling efficiency and makes my engine more reliable, I'm happy ![]()
Merv,
Thanks to 930Rocket I will attempt to send the pics of the cheap IC seal. ![]() HOORAHH!! It came through!
911rudy |
Me like track days
Is the rest of the tail blocked off - or nearly so?
Yes it is like yours only with a strip down the center and the AC cond. on the other side.
911rudy |
Cool, thanks for the pic. Gives me an idea of how it should look then
Crotchety Old Bastard
I finally got around to taking some pictures of my intercooler shroud. The GT2 tail has a huge surface area, I am certain that no air was going through the intercooler. It was simply a heat sink sitting out in the air.
A very thin sheet of stainless was used with a hole cut in it to fit the intercooler core. Foam rubber was glued to the S/S and formed to fit the intercooler. The back end of the square hole was left open to allow air to be pulled in toward the air filter and to not choke off the fan. The results were no less than spectacular. I picked up a BUNCH of power, lost a LOT of lag, and raised the engine temp from 150F to 190F. The engine actually runs better. Too much cold air was engulfing the engine compartment and cooling the WUR and sensors causing the fuel pressure to be less than optimal. ![]()
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Me like track days
Excellent! Very similar to mine. Great use of air guidance to your filter.
Believe Brian's (cold weather, at a minimum) results - he is an experienced WUR 'fiddler'
Not quite clear in photo-- if you look at front of i/c ypu can see extended edge that runs around top of i/c with dressing strip running around the edge-- this is touch fit to vents in grill to outside the engine bay. Purpose was to exclude engine bay hot air and was definately effective.
Thread Tools | |
Rate This Thread | |
