OK, we all know heat soak in the intercooler after the car sits for a while robs your engine of precious HP until it cools down again.
So what are some of the solutions people have been using to minimise heat soak in these top-mount IC's? The only thing I can think of is a water spray kit, or perhaps even two large fans beneath the intercooler which periodically turns on to provide constant airflow through the core? I find it a bit of a pain having to wait ~10min for the inlet air temps to drop before I can start applying some serious throttle ![]() I've read that the WRX guys tilt their IC's to improve heat dissipation. This typically results in the lower intake air temps and the time taken for the IC to recover from heat soak is halved! Hmmm, maybe that's why the C2T units are tilted?!?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
My 2 cents...
If you are on track, after the warm up lap, with all the fresh air blowing thru it, it should be normalized. If you are on the street, for the amount of time that you can be on boost (<5 sec; or maybe its just where I'm ![]() I have just installed a new HUGE Bell full bay. Temp had been low ever since (max of 60degF/15degC), but my inlet air temp had never been a few deg higher than ambiance other than the 1st 2 min (after heat soak) before the car pick up any speed. BTW - I think this will be my 911 posts ![]()
87 930 K27HFS/B&B/Twin-Plug... Megasquirted ![]() |
Automotive Monomaniac
I don't think a water spray kit will help unless you have air flowing through the intercooler.
2012 - Porsche Boxster Spyder 6MT / 2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 2018 - Volkswagen GTI 6MT |
Porsche intercoolers have an advantage over the WRX or any other top-mounted I/C whereas it is forced-air cooled. The fan is capable of moving somewhere in the neighborhood of 2800 cfm of air with a rev of the engine - sitting still. A couple of late shifts under light acceleration and the heat soak will be long gone, way before the WRX has a chance to move enough air to make a difference.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait! |
Me like track days
Fan under the IC!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
![]() Personally, 10-15min to cool down is a bit too long ![]() The fan under the IC sounds like a good solution. Anyone got pics? How well does this work?
Me like track days
40 to 50C = 104 to 122 degrees farenheit -- for us good ol' USA guys.
![]() I also have the Davtron/Andial gauge - mine is hooked up for inlet temp and post IC temp. Cool down lap on the track takes only about 2 minutes to go from maximum (at times about 140+) to virtually ambient - After sitting, it takes about the same amount of time when back on track - on the street probably double at about 4 minutes. The faster the ground speed and higher the engine speed the better for my setup - it is a shrouded IC that does well with the fan pulling a majority of it's air through the IC. An under IC SPAL fan would really help with your concerns - IMO. Superb quality, huge selection - available on EBay and through Iowa Impot/Export here in the States.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 11-26-2006 at 03:38 PM.. |
![]() In traffic, it's a real b!tch to get the heat-soak out fast enough ![]()
Me like track days
See my addendum above ;-)
Thanks for that
![]() I'll check out the SPAL fans.
BTW, @ idle, would the SPAL fans really make much difference to the airflow into the engine bay?
Anyone know how approx many CFM's the engine fan is drawing into the engine bay @ idle?
Me like track days
Aren't you trying to cool the intercooler from at rest heat soak..........?
Yup, at idle, immediately after a period of rest.
Me like track days
IC fan. Bottom mount, pull type.
On a full-bay IC, where's the best spot to position, say a 12" fan? Closer to the inlet, or closer to the outlet (or in the centre)?
I guess it doesn't really matter as long as air is drawn through the core.
Crotchety Old Bastard
Merv,
Is your intercooler properly shrouded? If all of the air that feeds the fan has to first go through the intercooler you should not be having a heat soak issue. I have a question to add to this discussion. What do you do to shroud an intercooler that is NOT the full bay type? I fear that a stock sized intercooler would not allow enough air flow for the fan and it would try to pull hot air from the cracks in the engine tin.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
RarlyL8, I have no shroud surrounding my full-bay IC, so yes, there's a high possibility air is taking the path of least restriction
![]() I think I'll look into that first, before adding a fan below the IC. Certainly be less added weight too ![]() What are people using to shroud their IC's? Welding an aluminium shroud around the perimeter or something? Would greatly appreciate any pics!
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() Last edited by WydRyd; 11-26-2006 at 08:39 PM.. |
I used the dark gray one inch pipe polyfoam insulation, (The foam is about 2 1/2 inches in diameter) to surround the IC where the engine bay lid makes contact with the IC and it forms a real nice seal. It comes with a slit the full length of the insulation and is pre-glued with a sticky but not messy glue. If you just pry the piece apart and place it along the edge of the IC and miter the corners, it makes a safe non-marring seal. It also allows a little more tolerance because it crushes when pressed so it dosen't have to be an exact fit. I would try something like this for about $10 before I would spend a lot of money on fans and shrouds that are made of exotic materials.
911rudy Last edited by 911rudy; 11-26-2006 at 09:40 PM.. |
Thanks 911Rudy - sounds like a cheap viable solution
![]() Care to share some pics?
Me like track days
I'm not Rudy, but here is mine:
Thread Tools | |
Rate This Thread | |
