Me like track days
Craig 930 RS's Avatar
*Learn by asking questions and searching here and on Rennlist*
You need to know how this stuff 'works' before you go nuts with your wallet.....
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-14-2006, 10:11 AM
wcc wcc is offline
wcc's Avatar
Originally posted by NathanUK
I wouldn't go for the blownsix intercooler yet as they have not been proved to work. Stephen can supply you with a B&B intercooler that he assures is excellent. It is a copy of the 964t type.
You missed headers out. Headers will give you quicker spooling of your turbo and also add approx 25bhp.
If you don't increase the boost pressure you won't need a better intercooler & can always fit one later when funds allow. If you do the headers later your turbo, muffler etc will have to all come off again.
That's interesting, cause I would have thought with a larger turbo I would NEED a larger intercooler to get the temps back down. Right now I only get .6BAR boost. I hit it every time, that's why I bought a .8 boost spring.
I wasn't really planning on replacing the headers, but since I'm taking it all apart anyways, it sounds like it would probably be a good idea to add it to the list.
Bill
Old 12-14-2006, 11:09 AM
Send a message via AIM to Chuck Jones
Do any of you recommend sending your intake manifolds or the hot side of the turbos to Extrude Hone to have them polished? Then possibly to Swain for the ceramic coating? I've heard that the ceramic coating helps keep the heat down....can also be done on the exhaust manifolds and increases the flow efficiency. I saw the video clip from Extrude Hone and it looks like a great process that may have merit.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 12-14-2006, 02:07 PM
911Rudy:
I would be willing to rent your LM-1 unit to establish baseline A/F numbers on my stock 930. I am in Atlanta.
96 BMW M3 Coupe
89 951
Peugeot moped
Old 12-14-2006, 02:55 PM
A fellow Pelacanite
NathanUK's Avatar
Bill, as I said earlier the K27HFS will produce less heat at the same boost pressure than the stock K26. If you are not on a budget then yes, get a B&B IC as well.
I really need to get a LM-1 and an adjustable WUR as I also have a modified fuel head from IA. More £££/$$$...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-14-2006, 03:00 PM
wcc wcc is offline
wcc's Avatar
Yeah, I really don't have a budget. I know that's bad, but when I come up with an extra grand or so then I start looking around for a part. I'm not planning on installing anything until I have all the parts collected. Cause I don't want to take everything apart a bunch of times.
Too bad I don't have more set aside cause there is a B&B intercooler in the classifieds section, but it's too much considering I just picked up a new K27hf.
Back to intercoolers, I kinda got the impression from threads, used prices for OEM intercoolers, etc, that they were about useless. But you are saying that the are efficient enough to handle all the mods I've been talking about? So what would be the point of upgrading to a larger intercooler? Maybe I can skip it all together like you say.....
Bill
Old 12-14-2006, 05:29 PM
Crotchety Old Bastard
RarlyL8's Avatar
Intercoolers are free horsepower. They also allow you to run higher C/R or boost by cooling down the intake charge while easing the threat of detonation or engine knock.
The stock 930 intercooler (USA '78/9) will hold back a modded engine and not allow all the horses to run free. In my opinion a good aftermarket intercooler is the 2nd most important item to upgrade on a stock USA '78/9 930, the 1st item being the heat exchangers.
If you are going to mod your car in stages here is how I would do it:
#1 - Headers or Euro Heat Exchangers
#2 - Aftermarket Intercooler
#3 - Turbo
#4 - Cams
#5 - Higher Boost Spring (up to 1.0bar)
#6 - Go into the heads/engine and start over at #1
Old 12-14-2006, 08:05 PM
Me like track days
Intercooler improvements will never gain HP - they prevent the loss of HP.
A good rule to live by, FWTW.
Old 12-14-2006, 08:24 PM
RarlyL8's Avatar
"Intercooler improvements will never gain HP - they prevent the loss of HP"
Isn't that what I just said?
"The stock 930 intercooler (USA '78/9) will hold back a modded engine and not allow all the horses to run free."
Old 12-15-2006, 05:34 AM
wcc wcc is offline
wcc's Avatar
#3 - Turbo
#4 - Cams
Looks Good. I wasn't to far off. I'm just buying stuff out of order, but that won't matter cause they'll all go on at the same time.
I didn't plan on #4 or #6 as of now, and 'm going to run a .8 spring instead of a 1bar.
Has anyone heard anything about these headers?
http://cgi.ebay.com/ebaymotors/Porsche-911-turbo-930-exhaust-headers_W0QQcmdZViewItemQQcategoryZ33631QQihZ006QQ itemZ160038627855QQrdZ1QQsspagenameZWD1V
Ebay Item #:160038627855
Bill
Old 12-15-2006, 05:51 AM
Me like track days
For short bursts of speed on the street, you might not be nearly as concerned with buying a larger IC than if you had, say, a local autobahn or track days in mind.
For your use, the turbo + headers and a good AFR may be enough.
And a pull fan under the stock IC is a good idea.
You live in Michigan.....get headers with heat
Old 12-17-2006, 09:39 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
