Crotchety Old Bastard
RarlyL8's Avatar
"Ok, I just got off the phone with Imaginauto. They said that the Tial wastegate prevent boost leakage WAY better then the factory wastegate. Due to the internal plastic parts in the factory wastegate giving out faster. Now I think I'm leaning towards the Tial."
That statement is not apples to apples. If the stock waste gate is freshly rebuilt and the TiAL is brand new they would most likely function the same.
I have a rebuilt factory wastegate on my engine. It works perfectly with no boost creep. It pegs the same number every time like clockwork. If someone gave me a TiAL I would use it but I certainly would not label the factory unit faulty without first spending the $50 to rebuild it.
Old 12-13-2006, 07:12 PM
wcc wcc is offline
wcc's Avatar
Very good point. Man, this is hard. They convinced me with the whole factory WG bleeding boost problem. But I really haven't had an issue either now that you mention it. But I figured since it's going to be accessible that I might as well rebuild it or switch to a Tial.
Bill
Old 12-13-2006, 07:19 PM
Me like track days
Craig 930 RS's Avatar
Clarification:
B&B + stock perfectly functioning factory wastegate at .8 bar registered *exactly* .8 bar from 3,200 to redline on the Porsche factory test gauge - one marked in tiny graduations and about 1 foot in diameter. Quite the gauge! Impressively level and consistent readings throughout the range.
Now, the same B&B headers + Tial at .8 bar registered .90+.
Back-to-back comparisions. Acording to Brian Leask (adjustable WUR guy), this is pretty common.
Probably a function of wastegate pipe size in relation to how the WG senses boost - my guess. Just be aware tha this is a distinct possibility. Being off by .10 to .15 bar can make a difference.
Make certain that your factory WG is in fine shape. If it is, why waste money on a Tial. Mine was perfectly fine, but I bought a Tial anyway...
If I recall correctly, vital parts of the factory WG are impossible to rebuild due to NLA parts - or some such issue.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-13-2006, 07:27 PM
Porschefile's Avatar
Personally, I tend to look at it from the longevity factor. So the Tial will cost a few hundred more than rebuilding the stock wg. Well the Tial is built with far more superior materials and metals which will pretty much resist ALL corrosion and, theoretically, last longer than the car itself. Personally, it's worth it to me to pay more up front just for the fact that I'd likely never have to mess with the wastegate again. That being said, Tial wastegates are probably about the best quality ones you can get on the market. There are plenty of other manufacturers out there, such as Turbonetics (delta gates are CRAP; avoid 'em like the plague!), Greddy, HKS, Turbosmart......and the list goes on. Some of them make some decent stuff, though Tial's are so inexpensive anyways that you really can't do any better going with another brand.
Old 12-13-2006, 07:44 PM
Me like track days
This will help illustrate the boost differences:
http://forums.rennlist.com/rennforums/showthread.php?t=317339
Old 12-13-2006, 11:41 PM
well should any of you need any wg I have several new 46 tial here just sitting
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 12-14-2006, 03:40 AM
wcc wcc is offline
wcc's Avatar
Ok, well I've decided to rebuild the factory WG. Now, if for some reason I can't source the parts because of NLA, then I'll probably switch to a Tial. This seems to be resolved for me at the moment.
mb911 - I'll keep you in mind in case it works out that I need a Tial.
Thanks everyone!!!!
Bill
Old 12-14-2006, 04:29 AM
BlkBird's Avatar
So what size wastegate do we use? Looks like 46 is the one referenced... and this costs $470 ~ $550?
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 12-14-2006, 07:09 AM
David's Avatar
The 46mm is the direct replacement. The standard 46 has full fins and there's a special 46 for the 930 that has shorter fins to give more clearance for removing the valve cover. The special one is another couple hundred dollars and I don't know if anyone actually buys them.
2014 Cayman S
2011 Cayenne Turbo
Old 12-14-2006, 07:11 AM
The price is the same when I buy them from tial I never new they charged more in retail
Ben
Old 12-14-2006, 07:58 AM
Send a message via Yahoo to Lukesportsman
Sure, Ben. You can't charge us Porsche Enthusiasts the same as Honda Enthusiasts. First, the part would be junk and second you'd loose the chance to make big profits I once heard of some vendor making SS mufflers for a reasonable price. You could call it a Ferrari part and add 50% margins yet.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 12-14-2006, 08:36 PM
I look at these thing more of a service then anything . It was kind of my pet project and because of that I bought allot of WG and BOV from tial. Last time I got athe smaller version (930)quoted from tial it was something like 425. I would have to go back and look
Ben
Old 12-15-2006, 07:39 AM
David's Avatar
Well that sucks, I was told by a (usually) well respected dealer that there was a price difference and that they never sold the ones with the shorter fins.
2014 Cayman S
2011 Cayenne Turbo
Old 12-15-2006, 07:43 AM
Forced Induction Junkie
WERK I's Avatar
I bought my 46mm wastegate from a ricer tuner company. No fitment issues. It is mounted on B&B header system. The "fitment" issue is mute because it is so frickin' easy to remove the wastegate and swing it out of the way when adjusting the exhaust valves. The intakes should be so easy!
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-15-2006, 08:18 AM
I experienced significantly higher boost levels with the TiAL and B&B header combination that before. My 1B spring set up in the TiAL was netting close to 1.3B. I actually moved down to a .8B spring and was still reaching 1.1B.
Right now I am running a .5B spring with a EBC (which I am still trying to get familiar with).
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 12-20-2006, 10:09 AM
wcc wcc is offline
wcc's Avatar
It sounds like to me that your WG isn't functioning right. That isn't even close to your spring. You may want to look into why it isn't boosting at the spring rate. Maybe your spring is sticking? Maybe it needs to be replaced? It should be consistent with the spring. I'd be careful not to over boost. Hopefully, someone will correct me if I'm wrong.
Bill
Old 12-20-2006, 10:24 AM
Me like track days
Again, the Tial combined with the B&B usually results in significantly higher boost that the stock wastegate. FWII, this is with "the smaller WG pipe" - from what I've heard.
Old 12-20-2006, 03:29 PM
mark '87 930's Avatar
i was told the Tial is lighter!... anyhow, as some of you may recall I had to spend the big bucks and get a 46 MM Tial because my factory WG is seized onto my factory headers no longer on the car!
LOTS OF CASH.... I was in a bind as well, I needed one right away, so I had to bend over and then come home with the new shiny TIAL WG!
it ironically measured lower than stock boost, but I added a boost controller afterwords and adjusted as I wanted...
If I could have gotten my hands on stock WG, I would have bought that instead and saved my loot for an IC!
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 12-20-2006, 03:52 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
My understanding (From Stephen) is that GHL or B&B headers flow so much better than stock headers, there's a lot more flow going to the WG. I used a .8 spring in my Tial (and GHL's) to get 1 bar.
Old 12-20-2006, 06:14 PM
Me like track days
Yet if you take a set of B&Bs + stock WG, the boost is usually right on with a given spring rate.
B&Bs + Tial = A higher actual vs. numbered spring rate...and usually more than just a bit.
Old 12-20-2006, 06:56 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
