930s rule the wasteland
smog is not a issue I used to be and inspector and will probably renew soon because smog is coming down to us.
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
72T RS look 96 993 |
man this craps hitting the fan,rules were meant to be broken,if i have to get thru emissions ill just put the original stuff back on (wink wink)
still waiting , hopefully it will be on the truck this week.
![]() Quote:
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
im gonna try to post pics of this car
![]() ![]() ![]() if any 1s in the houston area let me know if this car exists or if im getting hosed pete
Salute
Im sorry if Im barking orders, I just got excited when the emissions guy told me that the computer kept asking if the probe was in the tail pipe as it was reading such low numbers. I think I got 4 ppm hydrocarben, .04% carbonmonoxide, and .02% carbondioxide. Those are low enough numbers to make a Honda hybrid look like a dump truck. However, they did not test for Nox, in which case I may have had a big problem.
when you generate a lot of heat like the lean condition nox usually goes thru the roof. I have to find out if this car is for real,this is gonna be my finally attempt on this car.
I got it to pass! ![]()
hey man a win is a win
heres the front of the ghost car
Low Speed, High Drag
"Sweet car" says Napolion
cmon people this is serious ,if this clown doesnt send the payoff saturday im gonnna take my bread and get the 86 w/390 hp,my only concern is a pulled headstud from overboost.i dont mean to act like a vag but this has me stressed.
the 80 has to be more sophisticated than the 86.cis is a ***** to troubleshoot sometimes ,worse if you dont have the right tools
I would suggest you get a PPI done. (at a reputable Porsche shop) I'm not sure how far Dougerty's is from you. He might be a good place to start. Have the Mech pull the valve covers and check for any broken cyl head studs, get leak down check done as well. It'll cost you but save you in the long run.
Good luck
South Shore Performance (Facebook us) Freeport NY FIKSE Dealer BBS Dealer |
they did send it to a porsche dealer and they said the oil leak is at one of the head gaskets.the car is modified with k27 turbo,kokeln intercooler,andial fuel enrichment ,premitire ignition sys(i think)and a boost controler they said it dynoed at 390 to the wheels.the car runs fine i just dont want to purchase something that im gonna have to tear down and split the case to get case savers put in.
Thread Tools | |
Rate This Thread | |
