Me like track days
Craig 930 RS's Avatar
Hey thanks for the love. It is a ton of fun......even after a ton of money - for the rather premature rebuild.
Luke, thanks for the edumacation ;-)
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-04-2007, 06:58 PM
Brando
quattrorunner's Avatar
OK, on liquid, is there a better option for the liquid than straight water? Anyone know the best way to make a liquid cooler more effective? I love the idea of liquid cooling for a lower boosted car because I like the look of my engine compartment without the big plate on top.
Turbo powa!
1977 911s. it's cool
Old 01-05-2007, 10:33 AM
A fellow Pelacanite
NathanUK's Avatar
There was a product called "water wetter" many moons ago...
http://www.redlineoil.com/products_coolant.asp
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-05-2007, 03:05 PM
Brando
I used it here in vegas in an old audi and it didn't quite do the magic I had hoped it woul
Turbo powa!
Old 01-05-2007, 03:10 PM
A fellow Pelacanite
NathanUK's Avatar
It probably makes 1% difference hehehe.
Old 01-05-2007, 03:16 PM
Brando
Yeah, cool color though
Turbo powa!
Old 01-05-2007, 03:30 PM
A fellow Pelacanite
NathanUK's Avatar
What colour is it ?
Old 01-06-2007, 03:47 AM
Stranger on the Internet
patkeefe's Avatar
I am toying with the idea of a water/air intercooler...I don't want to replace the stock deck lid on my SC.
I currently have water injection in the engine. It seemed to work well in the 500 miles or so I had the engine together (pulled it back apart for a separate issue). No detonation at 7-8 psi boost, even at the track.
This discussion flounders a bit without quantifying what's what. When my car goes back together, the instrumentation package will include a boost gauge, cylinder head temp gauge, intake air temp gauge and AFR meter. I believe the intake air temp gauge will reveal a lot of good data...how much heat can you reject, and how efficiently can it be rejected.
Craig: nice link, BTW. I have another one somewhere; I'll post it when I locate it.
Pat
Patrick E. Keefe
78 SC
Old 01-06-2007, 03:56 PM
Send a message via Yahoo to Lukesportsman
Craig,
All tongue and cheek. I hope it was taken as such..sometimes forget that sarcasm doesn't convey well over the keyboard.
I also contemplated the air/water thing for a turbo setup on the 72 to keep it below the decklid. I have 3 different IC setups in the garage trying for a setup I felt was ideal. Now going NA on 72 and will build the turbo in a chassis that will have a tail. I've got some ideas, Pat, if your interested let me know.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-06-2007, 07:55 PM
Randy Blaylock's Avatar
http://www.evanscooling.com/main20.htm
Bullet Racing #22 GT3 Cup
Old 01-06-2007, 09:47 PM
A fellow Pelacanite
NathanUK's Avatar
Thats stuff seems good.
What it doesn't tell you though is how thermally conductive standard water & antifreeze is to compare it to.
Old 01-07-2007, 02:00 AM
David's Avatar
We used Redline water wetter instead of glycol and the corrosion was bad. I'd stick with distilled water with a little glycol antifreeze.
2014 Cayman S
2011 Cayenne Turbo
Old 01-07-2007, 06:15 AM
gtu935's Avatar
Send a message via AIM to gtu935
TPC offers air/water intercoolers on their Supercharger kits
South Shore Performance (Facebook us)
Freeport NY
FIKSE Dealer
BBS Dealer
Old 01-07-2007, 07:18 AM
targa72e's Avatar
The idea behind water wetter is to lower the surface tension of the water to eliminate localized boiling in the heads. I do not think it would help in a water to air intercooler.
john
Old 01-07-2007, 08:54 AM
David's Avatar
Some questions and my thoughts on 930 intercooler design:
(please add your questions and thoughts or tell me why mine are wrong )
Flow front to back or side to side?
Many books state that most heat transfer takes place during the first few inches of the intercooler passages. This favors the front to back. If this isn’t true, the side to side might be more efficient.
The front to back has more hot air area so there’s less restriction.
Since the front to back has more area, the air moves slower and has more time to cool.
There are some high hp 930’s out there with side to side, so what are some benefits? Has anyone done back to back comparisons?
Full bay?
Seems like a no brainer here. More cooling air surface so more efficient.
Thick or thin core?
Thin is lighter.
If most heat transfer takes place in the first few inches, then thinner should be adequate.
If you live in an area with hot and humid air, a thick core might help by giving more time for the heat transfer to take place, it might also act as a better heat sink due to the added mass.
Bare aluminum, polished , painted, or anodized.
Bare aluminum is easiest and cheapest.
Polished would reduce heat transfer between the intercooler and the surrounding areas; if the engine is hotter than the intercooler, this would be better.
Painted would insulate more and reduce heat transfer so my vote is no paint.
Anodized black would increase the heat transfer so if the intercooler is hotter than the engine bay this would be better.
Splitters and end tanks have already been discussed in this thread so I’ll leave that topic alone.
2014 Cayman S
2011 Cayenne Turbo
Old 01-30-2007, 04:12 PM
David,
I appreciate the answer from the other thread. BUT, do you know of any formula for thickness to flow? Is there a calculation or was this just an educated gut decision as to 4.5 whopping inches? What are your efficiencies and temperature drops?
Do you feel a (front/back) short runner full bay thicker core is going to be the best choice. This would reduce pressure drop, maximize "first" inches of heat transfer, and minimize unnecessary volume. Am I following your thoughts fairly accurately?
Luke S.
Old 01-30-2007, 04:51 PM
Brando
Originally posted by NathanUK
What colour is it ?
neon pink.
Looks high tech.
Turbo powa!
Old 01-30-2007, 05:32 PM
Me like track days
Corky Bell & http://www.are.com.au/techtalk/intecoolersMR.htm
Old 01-30-2007, 07:00 PM
WydRyd's Avatar
Curious, for our cars, are the side->side end tanks better than the front -> back tanks?
I notice a lot of the full bay intercoolers have front - back tanks whilst others have side - side.
Any advantage over the front - back configuration?
Less lag and/or pressure drop perhaps?
I'd say a side to side tank config would cool better since the air stays in the core longer, right?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-30-2007, 08:51 PM
David's Avatar
Originally posted by Lukesportsman
David,
I haven't done any calculations on the thickness. The decision was just an educated guess with a few outside recommendations.
I built my intercooler with a front to back design because I feel it's the better design. I've wired my ECU for intercooler inlet and outlet temps but I haven't installed the inlet temp sensor yet. I doubt any one person here will run through the different designs to get good efficiency data, but maybe a few of us can post the data for our intercoolers so we can come to some consensus.
2014 Cayman S
2011 Cayenne Turbo
Old 01-31-2007, 04:36 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
