Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
7.0:1 > 11.3:1
Mine is 167 top and I find it on the edge as is. Need aspirin after about an hour on the freeway. I think I need a better muffler.
Jim
Old 01-25-2007, 07:24 AM
VZ935's Avatar
Send a message via AIM to VZ935
Originally posted by DDDD
Drive your car at 3400 rpms and see if it bothers you. I don't even notice.
Ooohhh.. I think it sounds great at 3500 or so...plus you can always step up the 4th gear a bit. As far as tracking the car, in my area a street turbo is not going to see 145 at Sears/Infineon , Laguna and would probably be just right for Thunderhill .
A bunch of old race cars
Old 01-25-2007, 07:37 AM
Before EFI & engine rebuild/upgrade, I was seeing 6200rpm @ the Glen before the bus stop
Maybe I'll need taller gear now with, hopefully, more ooomph...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 01-25-2007, 07:45 AM
Gino's Avatar
I TOO HAVE SHORTEN THE GEARS IN THE 4 SP BOX. I TOP OUT AT 145, AND WITH 390RWHP IT GET THERE REAL FAST. KEPT 1ST, AND CHANGED 2, 3 AND 4. MUCH HAPPIER, AND TREMEDOUSLY RESPONSIVE.
I COMMUTE MINE DURING THE SUMMER 103 MILES RT. ALL HWY, AND THE BUZZ GOT TO ME (B&B W/FABSPEED SINGLE) SO I REMOVED THE FABSPEED AND REPLACED WITH A COMBO OF BORLA/MAGNAFLOW. MUCH MORE QUIET, BUT LOST 15HP, DOWN TO 375... PLENTY FOR THE STREET.
-G
Old 01-26-2007, 02:17 PM
What are everyone's thoughts on the short geared R&P modification? I have one sitting in my closet that I was able to get for a song last year. Just can't decide whether or not to install that or new gears when my box gets opened up this year.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 01-28-2007, 04:31 PM
Crotchety Old Bastard
RarlyL8's Avatar
Using a 915 my top end is about 150mph @ 7000rpm. First gear is generally useless but the rest are just right. You do change gears a lot but they are very quick and you are always in boost. The tires take a beating.
I'm getting ready to try out a Euro 915 with a higher 4th and 5th gear. Should make for a nice highway ride.
It stands to reason that your gear spacing should match your torque curve and power output. If you have an engine that puts out more than 400HP you probably don't want an 8:39 R&P in your 4spd.
Old 01-28-2007, 06:09 PM
All you guys that are geared to top at 145, what's your 4th gear ration?
Rob Montgomery
Old 01-21-2008, 10:49 AM
Smart quod bastardus
fredmeister's Avatar
What R&P gears are you running too?
What was the cost to change out 2,3, and 4th gear ratios?
Seems like a R&P swap is alot cheaper overall.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-21-2008, 01:33 PM
Gino's Avatar
930 tranny gearsets
here are mine:
old and current 1st- 29:36 or 2.25 (that is stock)... good to 50mph
new 2nd 18:26, or 1.44 (stock is 23:30, or 1.30)... good to 80
new 3rd 26:27, or 1.038 (stock is 28:25, or 0.893)... good to 110
new 4th 29:23, or 0.793 (stock is 32:20, or 0.625)... good to 145
gearsets were $750 each set...
standard R&P 4.22 ratio... 245-45 tires on 16" fuchs
-G
Old 01-21-2008, 02:41 PM
kellcats521's Avatar
The R&P sells for ~$2K new, and most shops charge another $1K to install, so changing 3 gears (2,3,4) would be the same or cheaper, and generally works better, as the R&P swap tends to make 1st too short, especially in a modified car.
Old 01-22-2008, 03:47 AM
Great info.
This is what I am talking about!
Thanks guys.
Gino,
Where did you order the gearsets and who did the install tranny rebuild work for you?
Old 01-22-2008, 08:12 AM
Forced Induction Junkie
WERK I's Avatar
+1 (first gear, useless) Do a R&P and then change first gear to a numerically lower gear ratio.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-22-2008, 08:17 AM
Gino -
What RPM are you assuming for 145 in 4th?
Rob Montgomery
Old 01-22-2008, 08:27 AM
DSPTurtle's Avatar
Is there a good rebuild manual published for rebuilding a 930 transmission?
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 01-22-2008, 08:54 AM
WERK I's Avatar
Porsche Factory manuals on the turbo?
Dave
Old 01-22-2008, 08:56 AM
Gino's Avatar
gearsets
the work was performed by:
Eurotech Advanced Automotive
Bill Pfister
14 Grant Street
Framingham, MA
508-879-9911
pfisterbuilt@msn.com
the assumed 145 was at 6600rpm
-G
Old 01-22-2008, 11:37 AM
Small world... I grew up one town over from Framingham. My folks live in Natick.
Rob Montgomery
Old 01-22-2008, 12:11 PM
Alan L's Avatar
Where do you buy the gear sets from?
Alan
Old 01-22-2008, 02:36 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Here a post on pelican that I used: 930 transmission overhaul
Also, any factory book with pics and specs will help.
Old 01-24-2008, 08:46 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
