930 won't start
1986 930 turbo totally stock and unmodified. Has been sitting for a long time. Had the fuel dist. changed last year. Was running ok, then died and went to restart and popped a few time.
The things I have done are to check if both pumps run, yes.
To check if the spark is good. Pressed the sensor plate and it fired up and ran for a sec and would not restart.
The leakdown was great at 2% equally. I guess I have to check some stuff but where do I start?
Thanks for any help,
Mark
Old 01-04-2007, 06:16 PM
wont start or wont turn over? might want to replace the fuel if its been sitting for awhile
The 930 Conversion beast is gone. Where to next?
Old 01-04-2007, 08:17 PM
930gt-40r's Avatar
I have seen the mass-air get sticky after sitting for a while, the best thing to do is what 930zx stated. It is a little bit of a pain to run the old gas through though. I got my 86' that had not been driven in almost a decade with a half a tank of 93' from 98'. So I drained the tank, replaced fuel and attempted to start. Long story short, I ended up running the car on starter fluid until it passed the new fuel through the distribution block, took a long time, so dont get discouraged while you do yours.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-05-2007, 05:14 AM
Without a doubt it's the flux capacitor not discharging. Or possibly the wastegate support hanger bearing. Though it could be that darned Nancy Pelosi thing again
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 01-06-2007, 07:23 PM
I had a car that sat for years it was a stuck fuel distributor the old gas hangs the piston up . I also had bad injectors mostly plugged up .
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 01-07-2007, 06:36 AM
930gt-40r's Avatar
Yes Dan, those flux-capacitors can be a real problem, I also have had problems with the blinker fluid....
Kris @ Tech9
86' 930/GT-40R Sold
Old 01-07-2007, 10:20 AM
Darn that flux capacitor.
Dear Dan,
You found me!
Well it seem's to have me stumped. What was that " CIS separates the men from the boys?"
If you have time call me.
Mark
Old 01-07-2007, 10:38 AM
Suck, Squeeze, Bang, Blow, Dats what make the motor go (unless it's a dirt bike or Detroit)
CIS= Constantly it sucks
No Spark or no fuel ?
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 01-07-2007, 02:34 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Hey, you don't have time to be hangin out here, get back towork on that Pearl white pig's ear! And rest up because my 964 is comin in tomorrow too!
Gary R.
Old 01-07-2007, 02:42 PM
Not an x rated forum
Dear Dan,
I just want you to know this is a clean post and we won't have talk like that around here.
Any way, I am pretty sure it is not getting fuel on startup for some reason. I can get it to fire as soon as I slightly depress the sensor plate. As soon as I do the pumps run and I hear the freq valve runnin.
It fires right up and then dies. It won't refire unless I depress the sensor plate again.
I hate bothering you for this but, I know you know.
Is Nancy Pelosi a Republican?
Really thankful,
Mark
Old 01-07-2007, 04:28 PM
Gary,
I've been too busy looking for G car headers on Dipwad.com
Marky,
Have you checked the op. of the cold start valve? You've got to pull it out and watch it spray. After that vac leaks then mixture then pressures. I'd pull out the nozzles and watch them spray I bet they're clogged with shiite. Heard about your boy George's new plan B? I think he's calling it Operation Deja Vu
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 01-07-2007, 06:23 PM
930 will start!
Dear 930 dudes,
Thanks for all your helpful advice and comments, the fix is in.
Dan, you were right on the money, the vac leak bug strikes again.
The fitting in the center of the intake plenum below the cold start valve for the warm up idle bypass valve blew out of the intake manifold.
Leaving a quarter sized hole to suck in free air. I guess there was too much sucking here!
A little JB weld fixed the fitting in there for good. I think it was swaged or epoxied in or something, CARS!
Thanks,
Mark
Old 01-15-2007, 04:11 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
