7.0:1 > 11.3:1
A friend who I trust mount tires for my three piece rims. One time the silicone got rubbed hard by the tire bead when we dismounted or mounted. Had to remove the tire then clean off and apply new silicone the whole way around the rim because I was unable to tell if there was more than one cut in the silicone. After this happened we watch a little closer when changing tires.
On another occasion I put a new set of rims together and when I applied the silicone there were a few small air bubles which came out of the crevas where the two rim halves meet. It appeared that one of the bubbles poped and gave the air a path to migrate out. I found that if you run the tip of the silicone caulking tube pressed tight into the crevas between the rim halves the air gets pushed out in front of the silicone. No problems since.
Old 01-13-2007, 08:07 AM
SPYDER,
I'm in Corpus, here's a front pic w/out fog lights.
Jim
86' 951 2.8L
87' 951 Track Car
87' 930 Wife's Car
Old 01-13-2007, 11:54 AM
550SPYDER's Avatar
awesome!
___________________
Ryan
2001 996 Twin Turbo
1982 930
Old 01-14-2007, 06:40 AM
Porsche Junky
mede8er's Avatar
Love that search function...
Craig, I'm also looking at the Lindseys....what are those tire sizes on your Rufs.....
1986 930 RUF equipped
Old 02-10-2007, 01:18 PM
Me like track days
Craig 930 RS's Avatar
235/275 and there is no doubt that I could use a wider tire -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-10-2007, 01:40 PM
Send a message via Yahoo to Larry_Ratcliff
Old 02-10-2007, 02:38 PM
Mine are 9 and 11 X 17
Old 02-10-2007, 02:40 PM
Porsche Junky
mede8er's Avatar
Great job Larry!
What tires/sizes did you end up with...
Old 02-12-2007, 02:40 PM
Originally posted by mede8er
Great job Larry!
Thanks, I wish I would not have made it so nice though... I drove it a lot more when it was a stock 74
Old 02-12-2007, 08:03 PM
Porsche Crest How Bout These Pics???
Craig,
Here's my pics.
BTW, still running factory I/C under duck tail.
I think I filled out the wheel wells...275/315
Props to Bryan Beamont.
That white turbo'd car of yours is a beaut...
One of my favorites.
Good luck Craig,
Paul
1970 911 (SLVR/BLK/SRD)
930 RSR in "Excellence" Sept 2007 (SOLD)
1983 911SC EURO (SOLD)
Old 02-22-2007, 11:33 PM
Me like track days
Paul - Wow, very nice!
Very rare is the RSR look in red....
Old 02-23-2007, 07:54 AM
Porsche Crest Thanks Craig!
Hi Craig,
So, Do you think Lindsey's are for you?
You can even go wider if you choose.
Believe it or not...there is still a couple more inches on the inside.
But, I don't think it will benefit you on the track.
Although, it is mighty aggressive on the street.
Oh, you did mention for street use right?
Paul
Old 02-23-2007, 10:43 AM
Me like track days
I think Lindsey's look great and have proven to be a great wheel.
I wonder how hard it would be to fit 315s (BFG TA KD) on the back of the 930 with Lindsey wheels?
I suppose it has been done several times -
Old 02-23-2007, 11:21 AM
I'm mounting the BFG 315's on my Lindsey 11's right now. Mike Lindsey said they should fit no problem.
Old 02-23-2007, 12:20 PM
Me like track days
Excellent. So Mike knows the offset required for a 930 with 315s, thanks.
Jim, what was the wait time for your set?
Old 02-23-2007, 12:29 PM
I had to supply the 16's b/c Mike did'nt have time to round up donors- that took probably three or four weeks on my end. He might be flooded with cores right now- I don't know.
When he got all the cores, the build time was about two months. I think he was pretty swamped at the time.
BTW- he gave me specific front spacer/wheel stud extension information for fitting Big Reds in the future. He really knows his stuff.
Old 02-23-2007, 12:49 PM
Porsche Crest You're Look'n @ 315's
Hey Craig,
Guess you missed the note on my 1st post...I'm running 275's in the front and 315's in the rear with factory spacers.
Remember, my IROC/RSR is based off a 79 930. So it works. What do you think about the look?
You could also go 335's in rear but I would cut back on the spacer by an inch. Confirm that with Mike. Hope that helps.
Or if you want the biggest meats in town....you could ask mike if he can build you 12/13"rears and use 345/355's. There's lot's of room. Confirm with Mike.....He'll probably think you're crazy
It will look like a steam roller.
Paul
Old 02-23-2007, 06:08 PM
Me like track days
You're right, I did!
What make & model tires are those? I do like the black....
Old 02-23-2007, 06:22 PM
Porsche Crest I went with the Japanese Dunlop!
Sumitomo is known as the Japanese Dunlop.
Front 275-40-17
Rear 315-35-17
I was considering BFG and other brands...but I did not think they were 3X's better. These tires are extremely reasonable. If I decide to keep the car, I will purchase another set to have on stand by.
I have taken these tires up only to about 140. They did just fine and their lateral stick is a lot better then I expected. A lot of bang for the buck.
Sumitomo may lack the status of more expensive brands...but with the drastic changes I've made with my 930, I obviously don't follow the crowd.
I always ran Dunlop....then Kumho....now Sumi's on the 930. I would have purchased Kumhos...but they did not offer 315's in the model I wanted.
With your color car...I might consider the RSR finish on Lindseys. Black would look cool too....but I think the RSR finish would do your car's color justice.
Paul
Old 02-23-2007, 09:40 PM
Gasoline User
1974carrera's Avatar
Re: How Bout These Pics???
Originally posted by PAUL RODELO
...BTW, still running factory I/C under duck tail...
Paul
Paul, your car looks great after the transformation. Please post pics of your intercooler/ducktail. What mods, if any, did you have to make to the 'tail? Maybe it should be a separate thread, to preserve this one.
Thanks,
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2013 Cayenne GTS Schwarz
2019 911 GT3 RS Schwarz
Old 02-24-2007, 07:49 PM
