Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 trailing arm crush sleeve question
Do you replace crush sleeves between inner and outter wheel bearings when rebuilding arms? Or can they be reused if within spec?
Thanks-
Craig Backer
Old 01-16-2007, 08:58 PM
AFJuvat's Avatar
I always reused them if they were within spec.
No adverse effects.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-17-2007, 04:47 AM
David's Avatar
I reused mine and they tightened up just fine, but this was only because I didn't know any better. Duh.
2014 Cayman S
2011 Cayenne Turbo
Old 01-17-2007, 06:40 AM
930turbo's Avatar
I spent a considerable amount of time measuring stack height of the original and replacement bearings to see if the original sleeves could be used. There was no measurable difference between the bearings and I reused the sleeves, torqued as directed by the OEM and they work perfectly.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 02-06-2007, 10:45 AM
mjmoran's Avatar
I guess the big question to open back up this thread is WHAT is the original dim of the crush sleeve? Does anyone have a no used sleeve and an accurate caliper to measure for later reference?
Michael
PCA-INWR
356 Reg.
Early S Reg.
R Gruppe PNW
Old 04-21-2008, 04:03 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
