-   -   EFI - what are you using (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/325554-efi-what-you-using.html)
dyerkes 01-18-2007 12:39 PM
For those that have already converted to EFI, what management system did you choose, and would you choose the same one again? Also, given what you know now, would you convert to EFI if you had it to do over?
1986 911 Turbo
Looking to go EFI
kleinbbc 01-18-2007 01:19 PM
I have tec2 running my EFI. I'm getting ready to upgrade my ECU to DTA. You need to find a dyno shop that understands your ECU.
JimCulp 01-18-2007 01:49 PM
Autronic SM4- I'll let you know when we get it running.
Candelaria 01-18-2007 02:37 PM
DTA here,Candy.
dean 01-18-2007 04:04 PM
Re: EFI - what are you using
1986 911 Turbo
Looking to go EFI
DTA also. I think I would look really hard at some other systems if I were to do it again. And I would do it again in a freakin heartbeat. Progamable EFI is the best invention since turbos.
kellcats521 01-18-2007 04:44 PM
Not to make things difficult, but could the folks who have replied (or plan to) include a url or other info regarding the EFI system. I'm very experienced in tuning Bosch SEFI based systems - mainly modifying the OE Ford (which is all Bosch) engine management systems. I an 110% certain that I could take a Tarus V6 ECM, MAF and wiring harness along with a plug-in interface (www.eec-tuner.com - I've used these on 3 different cars including a 670HP n/a road race mustang where I totally modified OE Ford program), and adapt it to a 930 motor. I'll bet that is what most of these systems are - either speed density or mass-air Bosch systems with Ford harnesses.
kleinbbc 01-18-2007 04:57 PM
This is DTA I'm waiting for there new ECU S80
http://www.dtafast.co.uk/
Lukesportsman 01-18-2007 05:01 PM
"You need to find a dyno shop that understands your ECU."
If your not quite confident in your tuning ability, this can't be over emphasized. I have DFI on one of my cars and where I live I'm on my own. Sure it runs, but I haven't found a local dyno that feels confident improving on my skills. Its supercharged so I'd like a verification before the 700hp is unleashed fully. It got rebuilt after eating a piston landing in its last state running SDS.
I like the interface of DFI, but check for local support. I'm going to try Mega Squirt on my 3.0 ITB first, then if happy on the 3.x TT.
WydRyd 01-18-2007 05:14 PM
I run the OEM Motronic EFI system. OEM DME and OEM loom. I'm considering map/speed density and I think I will go with a modified Protomotive Motronic for ease of installation and comes fully callibrated with a base map for a 3.3 EFI Turbo and also bored out throttle body with appropriate IAT and TPS sensor already mounted ;)
mppickett 01-18-2007 05:31 PM
I'm running a MegaSquirt setup that includes both EFI and ignition (dual plug EDIS). Here's a link to some details.
I like doing it all myself and have a good electronics and tuning background. This is not a plug and play solution but since it is essentially open source hardware/software, there's a lot of support in the MegaSquirt community.
TimT 01-18-2007 05:37 PM
We have installed Haltech on a bunch of cars, from a Supercup we made into a twin turbo, to RX7 turbos, Supra Turbos, some Mitsus, and a bunch of other Porsche turbos (n/a also).
We have also installed Electromotives from way back, from the Tec1 up and including the Tec3.
We now have chosen to stick with Haltech.. the Tec have some weird quirks that we arent to impressed with. Not being able to grab a file from the ECU is just one.
On my personal car I installed a Link ECU its a good system, not well known here, but the sytem works fine, and the software is easy to use.
TimT 01-18-2007 05:49 PM
Many of the systems now can be based on manifold pressure (speed density), or throttle position (alpha-n) or a combination of the two. Wild cams screw up vacuum signals, you can set up mixed scheduling until you get into boost. etc...
oms930 01-18-2007 06:53 PM
Motec M48 - will also report when job done
kellcats521 01-18-2007 07:15 PM
S/D is great on a boosted car for just this reason - MAFs can lose accuracy in big cam, and/or forced induction use. If you have a good handle on all of the parameters needed, and you're not planning on changes (like stronger cams or increased compression, etc.) S/D is the ticket as you set it up once and you're done.
Tha MAF adds some flexibility, but possibly at the expense of some response/drivability....
ZLP 01-18-2007 08:21 PM
What about Simple Digital Systems? I was thinking about getting one of their ECU's for my conversion.
TimT 01-18-2007 08:36 PM
We completed the install of a SDS sytem for a customer who started, but couldnt finish the install. SDS is just what its name implies..simple..It is a very good system and easy to tune. No bells and whistles, no boost control curves, no fan or water spray circuits.. it has just what is needed to run the engine.
We have even been in contact with SDS about becoming distibutors.
David 01-19-2007 10:23 AM
I'm running a Motec M600 ECU and I've been having problems. It may just be software, my tuner has gone back to an earlier version and it seems to be working. He still hasn't completed the tuning so the jury's still out.
rotorhead 01-19-2007 11:08 PM
EMS Stinger 4424 here.... I'll post pics when the install is finished
ZLP 01-19-2007 11:16 PM
Do you think it would be good on a 930 to run in the 500hp range? How does it respond to the boost? I really have no need for boost control, traction control, etc. so I figured it might be a good system for my project. I am making some injector blocks right now and am almost done so I need to make a final decision before the summer!
Cheers,
hobieboy 01-20-2007 04:41 AM
Cheers,
Friend of mine used the SDS systems in his 934.5 replica for his few years without any issues - http://www.sdsefi.com/features/jan03934.htm
I chose to use Megasquirt however. Not as straight forward as it is a lot more DIY but its been fun & has quite a number of good features.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
