longevity of 930 bottom end
HI all,
How many miles could one expect from the 930 bottom end if the car is not tracked, raced or abused? What have your experiences been with the motor bottom end? Vincent |
Re: longevity of 930 bottom end
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
Thank you sir! I just finished the longevity section in Wayne's book. It looks like I'm in for many years of exhilarating fun.
my 930 has just over 160,000 miles on it and is now due for a top end rebuild only. just for ease of mind i'm taking care of bottom too even though my mechanic said it doesnt need it. If i was you i wouldnt worry till you have to take care of the top; which will usually go first...
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
By top end.. do you mean the heads only, or does that include the P's & C's?
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) |
Hi neighbor had his top end rebuilt for $9,000
This included everything from piston rings to valve steam seals. The P/C were in spec and reused. I do not know if this is a fair price or not but he car runs nice and zero oil leaks. Anyway his is very happy with his rebuilt motor. I still wonder if $9,000 is too much for his top-end rebuild. He laughed at me when I was rebuilding my Isuzu rodeo but the I explained I wanted motor rebuild experience of any kind to develop my skills. He was impressed with all the manuals and tools I collected over the years including a complete MAC TOOL CIS tester, valve seat grinder, and 70's Snap-On valve grinder which I refurbished to grind my own valves and seats. I explained that I was preparing to own my first used 930 and wanted to be ready to handling maintain and repair my own 930. Five years and two Isuzu rodeo rebuilds ( I have two rodeos) later I finally bought my first 930 and I so excited I cannot focus at work or sleep at night!! I just need to learn turbo charging theory and all this hype about boost. Last edited by vmisquez; 01-19-2007 at 07:26 AM.. |
the top end includes the p/c's. its only running on 5 of 6 cylinders so im using this oportunity to do a complete rebuild and upgrade to 3.4L twin plug
It depends on the amount the car is used. I have what some call a garage queen and when I pulled the motor apart found that the lay shaft and main bearings were like new however the rod bearings had some light wear. I probably could have run it like this for a long time to come however upon inspection of the inside of the oil pump, much corrosion was evident. I talked to Bruce A. and described my findings. First thing he said was "Does this car sit lots ??"
Extended sitting time is bad for a car as well. My oil is always changed in the fall before parking it. Thanks Jerry S,
Mark TURBO = Free Power |
Automotive Monomaniac
Mine has 139,000 miles on it. Never opened (except for valve adjustments).
2012 - Porsche Boxster Spyder 6MT / 2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 2018 - Volkswagen GTI 6MT |
930s rule the wasteland
does any one recommend a additive to clean the spray bars for the rocker arms?
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
Thread Tools | |
Rate This Thread | |
