Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
KCPSG's Avatar
Here are a few pics of my oil return to the sump.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 01-24-2007, 11:01 AM
Brando
quattrorunner's Avatar
OK, that is a good idea, but it can't apply to my sc could it. I mean, if I had that on mine, it would hang down too much?
Turbo powa!
1977 911s. it's cool
Old 01-24-2007, 11:06 AM
WydRyd's Avatar
Nice Phil, what kind of turbo is that? Garrett?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-24-2007, 11:09 AM
nope it will wrok trust me I will post pics shortly..
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 01-24-2007, 11:36 AM
KCPSG's Avatar
Turbonetics
Phil
1998 BMW 328i
Old 01-24-2007, 12:10 PM
Ben are you using that finned sump plate. I think it's made out of alum.
1983 911SC Widebody
Old 01-24-2007, 12:35 PM
WydRyd's Avatar
Can you just confirm what size fitting is on the sump bolt?
Merv
'89 911 Turbo Cab
Old 01-24-2007, 01:35 PM
A fellow Pelacanite
NathanUK's Avatar
That looks pretty cool. No additional tank to worry about.
I wonder if there is any weight saving compared to the 930 setup. I'm thinking there is.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-24-2007, 01:52 PM
KCPSG's Avatar
if you are asking me Merv
it's -10 X 20mm 1.5 union
Phil
1998 BMW 328i
Old 01-24-2007, 01:54 PM
[QUOTE]Originally posted by Roaddawg
Ben are you using that finned sump plate. I think it's made out of alum. [/QUOTE
yup
Ben
Old 01-24-2007, 02:07 PM
WydRyd's Avatar
For sure! No mechanical (or electric) scavenge pump and associated lines required... just drain straight into sump bolt
Thanks for clarifying KPSG.
Merv
'89 911 Turbo Cab
Old 01-24-2007, 02:16 PM
kpsg and jbrinkly and I all use the same Turbonetics TO4E it works very very well.. and also the same basic drain set up
Ben
Old 01-24-2007, 02:53 PM
here is the link to watch over the next week I will finish the project and hopefully get it running
my 3.2 ss/twin plug/turbo motor
Ben
Old 01-26-2007, 10:50 AM
one of the great unwashed
patkeefe's Avatar
So, what I want to know is...do any of you guys run these turbos at the track, and do you have any drain problems when you basically stay on boost at high RPM for 20 minutes or so?
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 01-26-2007, 05:35 PM
Pat
When I spoke with henry@supertec he said his 914-6 turbo was run the same way and he use to pound that car what he said so if it works for him nuff said IMHO
Ben
Old 01-27-2007, 04:12 AM
patkeefe's Avatar
OK, sounds good to me too, Ben.
BTW, I need a muffler for the 914 track car.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 01-27-2007, 04:29 AM
A fellow Pelacanite
NathanUK's Avatar
If my pump ever packs up I will check with Kevin and do away with that pump.
Old 01-27-2007, 01:59 PM
Pat
the only draw back on an sc is that where it drains has no screen in it so it can't really be filtered.. but other then that nothing to go bad as it draws directly off the scavange of the oil pump thats part of the reason I had my sc pump modded to flow 30% more
Ben
Old 01-27-2007, 02:50 PM
ok here is mine
Ben
Old 02-01-2007, 04:32 AM
Brando
Ben, you had me thinking it would be easy to get the drain idea on the sc sump. Yours looks very effective, but where did you get it done?(you I'm sure) can you sell it if I needed it/ asked for it?
Turbo powa!
Old 02-01-2007, 07:24 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
