plugs
anyone using the 12mm plugs for the second set of plugs?? I am going to order a set here pretty quick but curious what others run what they have found to work best Thanks
Ben
Current project 73 914-6 Gt project rusteration 2.4
914-6werkshop.com ,heat exchangers, oil tanks, etc
Old 01-20-2007, 06:46 PM
Gotta Jibboo
BSiple's Avatar
Send a message via AIM to BSiple
I just had all of mine changed. It had Bosch's in it, but they were too big and tough to get in and out due to clearence issues.
I think they are Bosch W4CS's to be honest. They are on the cool side.
Bill
2003 996TT
1992 964 Turbo (sold) Holy crap are these expensive now!
1986 911 Cabriolet (sold)
I don't know why I do the hillbilly things I do.
Old 01-20-2007, 08:02 PM
resident samsquamch
sand_man's Avatar
My car is twin-plugged, but I have 14MM plugs all the way around. FWIW, I'm running Bosch Silver W4CSs in mine. They are slightly hotter than stock, which is W3DPO. So far so good. I've heard that Bosch plugs in the 3 heat range are too cold for our engines...on the street that is. A race car might require a colder plug, but even then I've heard of racers running the W4CS with good results. I think Craig911 runs W2CS (colder) in his race car.
-jeff
Old 01-21-2007, 03:56 AM
resident samsquamch
sand_man's Avatar
A good discussion:
Spark plug & gap - yours?
-jeff
Old 01-21-2007, 03:58 AM
WydRyd's Avatar
I've always run W3DPO in my car (street only) and I find they are too cold and foul up too quickly. I'm about to go with W4CS and will see how they go. Geoffrey from Rennlist recommended them. He uses those in his track car and has for many years.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-21-2007, 12:13 PM
Gotta Jibboo
BSiple's Avatar
Merv,
The guys at Imagine Auto recommend them for my car as well, after they listened to what had been done.
Bill
2003 996TT
Old 01-21-2007, 12:50 PM
WydRyd's Avatar
I'm hoping the W4CS's will last significantly longer than the DPO's and provide better street performance... damn those DPO plugs are expensive
Merv
'89 911 Turbo Cab
Old 01-21-2007, 03:05 PM
what? me worry?
TimT's Avatar
We have had good luck running plugs like NGK R5671A-(7,8,9,10)
its a 14mm plug with 5/8 hex for the wrench.. so you dont have the interference problem like when you try to use full size plugs for the lowers
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 01-21-2007, 04:42 PM
WydRyd's Avatar
I have also heard the NGK's are a good cheaper plug.
You do need a good plug if you want to run the larger plug gaps with an aftermarket CDI unit(s).
Merv
'89 911 Turbo Cab
Old 01-21-2007, 05:31 PM
nonody is running 12mm??
Ben
Old 01-21-2007, 06:08 PM
what? me worry?
TimT's Avatar
We used to have the heads machined for 12mm...We decided 14mm was better because of more plugs available that fit
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
BBS wheels
Fikse wheels
Redline motors oils
Swepco
Old 01-21-2007, 07:01 PM
David's Avatar
My second plug is 12mm. I'm using NGK BPR8ES for the upper plugs and DPR8EA-9 for the lower plugs.
2014 Cayman S
2011 Cayenne Turbo
Old 01-22-2007, 10:31 AM
Why different plugs for upper and lower?
Old 01-22-2007, 11:01 AM
David's Avatar
The relief around the larger plug seamed rather large so I chose the smaller plug to minimize the material removed from the combustion chamber. I'm guessing it saved about 1cc.
2014 Cayman S
2011 Cayenne Turbo
Old 01-22-2007, 01:30 PM
Macht Schnell
les_garten's Avatar
Hi Tim,
I've been advised by my Tuner to get R5671A-8's. I'm running BP7ES presently because I was just tired of Black plugs over the years. What is your experience with the 8 heat range?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 01-02-2008, 06:52 AM
