kellcats521's Avatar
Question swapping to 91-92 P&C's on an 87
Has anyone 'upgraded' their pre '91 3.3L by swapping to the '91-92 all finned P&C set? If so, any modifications needed on the tins on the cylinders? I'm looking at a new set of these that are being sold almost too cheap to pass on. I've heard that they'll run a bit cooler than the half-finned originals, but I wasn't sure if they are a 'bolt-in' upgrade or if there's more to the picture....
Thanks!!
Old 02-06-2007, 11:53 AM
WydRyd's Avatar
I have fully finned 97mm cylinders in my Carrera motor. I don't think any extra machining was required as such to make them fit.
I had the base of the cylinders machine as I was running thicker (0.5mm) base shims as well as the 0.5mm C2T head gaskets.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-06-2007, 02:18 PM
