Gino's Avatar
"tasteful" weight reduction
I'm looking to remove some 'excess weight' from my modified 930. Does anyone have a 'list of items w/weights' that could be posted.
I would imagine significant reductions from:
1. power seats, in exchange for lite wt. racing ones
2. removal of all A/C components
3. back seat and bench, replace w/lite wt. carpeting
4. standard door panelw/pocket, exchange for RS w/door pull
5. battery exchange for Optima
6. rear window, exchange w/lt.wt. polycarbonate
7. blowers in the foot wells
perhaps add up to approx 250lbs..??? for a few hundred $$???
'Tasteful', to me, would mean not like it was radically missing stuff.
-G
Old 01-27-2007, 10:54 AM
Driver
Noah930's Avatar
I'd think the AC components would come pretty close to that 250 lbs all alone?
Swapping the impact bumpers/shocks for fiberglass covers would probably save a bit more, too. Swapping stock hood/whaletail for fiberglass ones, too.
1990 Black 964 C2 Targa
Old 01-27-2007, 01:35 PM
I could be wrong but I thought the whole ac system added up to around 80 lbs.
There's also the spare, jack, tools and sunroof delete if you've got one.
Old 01-27-2007, 07:24 PM
Crotchety Old Bastard
RarlyL8's Avatar
What does your car weigh now?
As a simple point of refrence I have an option delete '78SC with steel 930 fenders, power nothing, FG bumpers, no sunroof, 930 engine and 915 tranny. Wieght with a full tank of gas is 2720 pounds.
I have a full interior with manual sport seats and carry tools and a spare. I'd like to get below 2500 pounds but do not see how that can be done and still retain a comfortable street car.
Old 01-27-2007, 08:09 PM
7.0:1 > 11.3:1 > 7.0:1
FWIW my stock 930 rear bumper weighed 45lbs including the bumper shocks and the tin heat shield. I replaced it with a "tasteful" RSR style glass bumper from Rennspeed which weighed 6 lbs. Might have added two lbs of heat shield mat and silicone etc. The glass bumper is tasteful, but my front bumper still has the rubber bellows which now look out of place.
Jim
Old 01-28-2007, 07:23 AM
Send a message via Yahoo to Lukesportsman
*Is your exhaust stock?
*What year?
*Not cost effective as #'s but may enhance overall: lightweight clutch/flywheel if longbell
*If upgrading TB's or Sway go hollow
*Loose the Lloyd mats
*I'd consider the Poly window kind of extreme if cars sees much street use because of scratches
*new carpets lends itself to loosing console
*foglights = brake scoops
*CF sunroof panel to get weight out of roof and could be reversed rather than welding
Yeah, I would also have to agree with A/C being closer to 80lbs depending on year.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-28-2007, 07:40 AM
David's Avatar
A/C off my 79:
Compressor Brackets 5.33
Ft. Condensor 2.89
Rear cond. And comp 23.80
Fan 3.47
Ft. Cond Fan 2.04
Left hose 6.11
Evap and Rt hose 8.82
Dryer and hoses 3.59
Hose brackets 0.99
Ft cond guard 1.98
AC total weight 59.02
My car weighed 2900 before my project started and weighs 2766 now. I can still drop about 80 lbs with new seats and wheels, but I'll add it back with a new A/C system.
The other big loss items were the clutch and the CIS system. Unfortunately my monster intercooler weighs 30lbs.
2014 Cayman S
2011 Cayenne Turbo
Old 01-28-2007, 08:14 AM
Thanks David for exact A/C weight. How much did/does factory IC weigh in comparison? 30# for the added efficiency and thermal load doesn't seem that bad. Too bad its up top.
Luke S.
Old 01-28-2007, 08:33 AM
How much weight have you guys been able to get rid of by switching between stock carpet and RS style carpet and door panels?
Is it necessary to scrape out the sound insulation inorder to get much savings from this mod?
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 01-28-2007, 04:26 PM
WydRyd's Avatar
IMO, tasteful weight reductions can be gained by going with f/glass RUF style front and rear bumpers and also a f/glass wing. The OEM stuff is pretty bulky and heavy
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-28-2007, 04:43 PM
How much louder are our 930s when you pull out the factory carpet and sound deadening in exchange for a RS carpet kit?
I am going to start this project next weekend but if the thing is going to be ear bleeding loud without some substitute sound deadening I am not sure if I will take the time to try and pull that crap out and rather will just swap carpet.
Rob Montgomery
Old 01-28-2007, 05:24 PM
Randy Blaylock's Avatar
Here's a chart with real world germain data;
http://www.early911sregistry.org/jcalziaweights.htm
Bullet Racing #22 GT3 Cup
Old 01-28-2007, 06:09 PM
Garen's Avatar
I'm in the process of taking some "tastefull" weight out of my car as well. So far, I have 154lbs out, here's what I've removed:
rear seats, carpeting, qtr panels, sound deadening, rear seat belts, radio, speakers, A/C (completely, all hoses etc.), rear wiper, door panels.
I have yet to install the RS carpet kit, and I'm also putting in a Heigo roll bar (very light, will post weight when measured). Plus, I will be replacing the seats this spring. I'm hoping for a total loss of around 300#, to be offset by the new seats, RS kit, and bar.
The car is louder, as I did get a chance to drive it w/o any carpeting, but it wasn't loud enough fpr me to complain. I think the engine sound pad is still in place. It too will get the boot when I get around to it. I'll post some pics and actual component weights later. The sound deadening was by far the heaviest.
Also, the battery will be replaced with a 15# Odyssey unit. My goal is to have the car look "complete", hence the RS carpet kit.
Garen (87 930 track rat)
Old 01-29-2007, 03:15 AM
David's Avatar
I didn't write down the weight of the B&B I pulled off, but I think it was 12 lbs, so stock would be under 10 lbs. I used a 4.5 inch core for my intercooler. If I lived where it wasn't so hot and humid, I would have used a 3.5 inch core so it isn't so heavy.
2014 Cayman S
2011 Cayenne Turbo
Old 01-29-2007, 04:28 AM
Wow, David 4.5"
OT OT OT
How do you determine the trade off of heat sink/surface area vs. air flow through the core? When do you make this compromise and to what extent?
Luke S.
Old 01-29-2007, 05:19 PM
sound damping thing? the black coating under the carpet!! does any one knows about the weight?
Old 01-29-2007, 11:09 PM
Also anyone have any decent feed back on the level of sound increase by removing such material?
Rob Montgomery
Old 01-30-2007, 10:22 AM
David's Avatar
Wow, David 4.5"
OT OT OT
I'll answer this on the intercooler 101 thread Craig started so it's easier to find later.
2014 Cayman S
2011 Cayenne Turbo
Old 01-30-2007, 03:43 PM
930gt-40r's Avatar
That $h!T is heavy and is dead weight. Inside the car may be a tad bit louder, but these are not hyundias, porsche uses thick metal and/or uses enough undercoating to negate the sound enough. And nevermind if you have a window leak that you dont know about, the micro foam that they use acts like a sponge in the presence of water and then gets real heavy.
If you are talking about the tar pads under the seats and footwells, they are good for about 7 lbs a side
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-02-2007, 08:29 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
