gotta remember Phil and jbrinkly are both running .5 bar with stock Internals and they love it.. It all depends on if you want to tear into the engine now or later.. I personally would not tearinto it unless I was changing P&Cs.. this would be the best way to go
Ben 914-6 2.4s GT tribute. 914-6werkshop.com manufacturer of 914-6, GT, Conversion parts |
Twins are more fun!
Guys, where can I tap the oil feed from?
What length and sized line and what fittings do I need? I've decided on the GT30R as it will give me best response and is within the HP goals I'm looking at.
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
The usual method is to use a -10 line off of the oil temp sender-you'll need a banjo on that end, along with a male/female adaptor that is drilled for the banjo. I'm sure Ben or someone can point you in the right direction for the parts.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) |
A fellow Pelacanite
Take a look on PET at the stock 930 setup.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 02-10-2007 at 08:18 AM.. |
you can also use -4 (W/a restrictor) for the feed line. And use -10 for the oil drain line back to the case. There is a large thread in the turbo forum about drain options. BTW I used 3' of -3 hose for the feed line.
Phil 2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift 1988 911 coupe (GP white) Turbocharged 1998 BMW 328i |
Here is a pic of the T
Twins are more fun!
Nice "T".. where can I get one from and how much are they?
My Garrett dealer told me -4AN unrestricted to the GT turbo due to the lower oil pressures of the air cooled flat6 ![]()
Twins are more fun!
Thanks Ben. How much are they?
Also, are the braided stainless steel oil drain lines suitable to run over/near hot header tubing?
I have the braided oil lines to and where are you running the braided oil line near the exhaust?? email me for pricing ben@mkexhaust.com
Twins are more fun!
Curious, would a 14" long -10AN braided s/steel oil drain line reach from the turbo oil drain flange to the sump drain plug on my 3.2?
I'll be using Schnell 930 headers, so the turbo would be in the location where a typical 930 turbocharger is.
Twins are more fun!
Here's a picture of what I'm considering for oil drain (it's -10AN, 14" long):
BTW Ben...(Not trying to Hijack this thread) that 90* bend you sent me looks like it's going to work for replacement of the boot. I have some 3/4" and 1/2" pipe I'm going to weld on for penetrators for the P/L in the rear and the ICV connection in front. Just tryng to source some silicone connections 3 1/4" to 3" (throttle body to 90*) and 3" for 90* to AFM.
On a side note...the constant torque hose clamps that Merv suggested have worked perfectly. The boot has not separated from the AFM since I have put them on...however before I put the IC on, I would feel far better w/the rubber boot being gone/replaced by something I will never have to worry about failing.
Cool. I am sure jerry will be calling as soon as he gets back for one of those as well
Thread Tools | |
Rate This Thread | |
