930turbo's Avatar
One other thing to consider about Porsches and oil pressure; the oil pump also doubles as a replacement for what would be a water pump if they weren't air-cooled. Because of this, the pumps are very large, nearly over-kill. Compare one side-by-side to a detroit example. They engines survive on oil volume as well as pressure. Many of the circulation speed secrets of the detroit models are alreadt applied from the factory in a P-car, such as double-drilled and chamfoured oil passages in the crankshaft. Again, my the thery on oil pressure; if it doesn't knock or explode, it's suffecient.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 02-09-2007, 03:59 AM
A fellow Pelacanite
NathanUK's Avatar
I too have heard about the GT3 pump being fitted.
I have no idea, but if that pump is used to feed the engine, what pump would then be needed to drain the engine ? Or does one pump do both jobs ?
TIA
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-09-2007, 10:37 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
