River Rat
Dave 86 930 Fl's Avatar
930 Brake Caliper Rebuild
I've been experiencing a brake lockup on the front passenger side of my car, so I'm in the middle of rebuilding the front calipers. I purchased a rebuild kit from Pelican that includes the rubber seals and dust rings, but I need to replace one of the pistons and I've been unable to find a source online. I'm going to call the local Porsche dealership on Monday. I'd appreciate it if anyone can direct me to a source for new pistons.
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 02-03-2007, 10:55 AM
GaryR's Avatar
Send a message via ICQ to GaryR
If you have a 1977 or earlier it's easy - http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BRKprf_pg11.htm#item10
Of course you and I don't, so I would like to have an answer also!
Gary R.
Old 02-03-2007, 12:39 PM
Porschephd's Avatar
Before you guys rebuild them. Try this. Compress the pistons back in and bleed the hell out of the system with a pressure bleeder. I mean BLEED THE HELL out of it. Push the pistons out, then back in and bleed again. Most of the time you will find that this is going to cure the stickys from sitting. Not to mention save a few $s in the process.
Now, if the dust covers are torn or you are leaking fluid all bets are off.
Stephen
94 3.6Turbo 6-speed AWD
Old 02-04-2007, 09:05 AM
GaryR's Avatar
I'm not experiencing a problem at this point, just rebuilding as part of track preperation and trying to get my ducks in a row IF I should need pistons.
Gary R.
Old 02-04-2007, 10:21 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
