Creeking Noise
I stirpped out the interior on my 930 yesterday, seats, rollbar, carpets etc in preparation for doing a lightweight carpet kit.
After pulling the sound pad in the rear I boled in the drivers seat so that I could take it for a spin to see just how much louder it is. Other than a couple of holes that were drilled through the firewall to run some wiring which were adding to the sound (and possibly carbon monoxide) It was louder but nothing that I won't be able to live with. What I did notice though was some creeking noises as I went over speed bumps. Essentially when the front wasn't level with the rear. Maybe its the lack of sound deadening, maybe the 2 degree Chicago weather, but I switched to coilovers last year and am concerned that maybe there is too much stretton the car. Or maybe there is something loose or broken somewhere. Any suggestions or thoughts? Thanks guys
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
no thoughts or suggestions?
1988 - 930 Porsche (track Car) 2002 - Panoz (track car) 2002 - 996 Porsche (weekends) 2006 - M5 BMW - (daily Driver) 2006 - F250 turbo diesel |
Me like track days
Sounds like you just removed the last bit of structural integrity from your car.
Put the carpet back in.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Hardy... Har... Har
Me like track days
I hope he hasn't.
Otherwise the "creeking" may tun into a torrent - a "river", if you will - of trouble. Glad we could help. P.S. Sounds like torsions
Torsions are removed via the coilover conversion... could it be torsion tubes?
Me like track days
My money lies on the a-arm/banana arm bushings.
A fellow Pelacanite
What rate springs are you running on the C/O's ? Without TB's ?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
KS Roadrunner
If you are not using 935 spring plates then it might be the original spring plate bushings.
Thread Tools | |
Rate This Thread | |
