Torque steer
Accelerating hard causes my 1988 - 930 to want to pull to the left. Lifting (like between shifts) makes it yank hard to the right. I知 told this is called torque steer. But I知 not sure that there isn稚 something else going on here or that maybe I have a suspension problem. Or possibly something on my suspension needs to be adjusted. The problem is so pronounced that I have to anticipate what is coming and actually turn the wheel slightly to compensate. My car has 356 RWHP - 411 torque, which I wouldn稚 think would be enough hp to cause this sort of issue. Does anyone else experience this with their 930?
1988 - 930 Porsche (track Car) 2002 - Panoz (track car) 2002 - 996 Porsche (weekends) 2006 - M5 BMW - (daily Driver) 2006 - F250 turbo diesel |
Is your car lowered? Does it have a bump steer kit?
When I bought mine, it did something similar. The front was lowered to the extreme - but with no compensation for the steering geometry. I thought torque steer was reserved for front-wheel drive vehicles. But, I'm wrong a lot. - Skip
1971 911T w/2.4 |
You might want to get an alignment. Do you have a LSD?
A fellow Pelacanite
Do you have matching tyres (and pressures) each side ?
Had it cornerweighted ? Faulty damper or insert ?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Crotchety Old Bastard
My car has similar power and does not do what you have described.
When the tires go up in smoke it tracks straight and true but may "fishtail" a bit. Clutching between gears is a non-event as well.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
First things first
First thing here is don't start over analyzing the problem. The FIRST thing to consider, is do you have LSD? A car making the power you are making (419 @ crank) with no LSD, and good hooking tires, will cause your car to go left when on the power. If and when you rule out the LSD question, then look onward.
And don't cut yourself short, you are making more power than most on this board with the 356 RWHP you are sending the the rear wheels. Curious as to the mods you have on your little beast!!!!!! |
So you're getting a little "squerly" when you get on it, huh? Sorry, I couldn't resist but it does sound as if one wheel is driving harder than the other pushing you off to one side.
--Mark-- 1979 RoW 930 1999 BMW Z3 Quote:
![]() ![]() Quote:
I still think that your car should track better than you describe.
With 350RWHP your car should be a handful, but with a 4spd and LSD it should still track straight. My car has ~300+RWHP but has a much lower geared 915. The torque multiplication of my 2nd gear is about the same as your 1st gear. I also do not have an LSD. You track your car and should know fellow reacers with similar setups that can give you some input. The common problems that cause the symptoms you describe are low tire pressure, worn tires, worn suspension components, broken front swaybar, bad SLD, things like that. I assume you have checked those things. Have someone watch your car from the rear and report what they see.
A fellow Pelacanite
This has been covered very well on the web. Wevo do some very good repair brackets. You remove your old and weld on the new !
I think there was another company as well. http://www.wevo.com/Products/ChassisProducts/WevoChassisProducts-RARBConsoles.htm ![]()
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 02-10-2007 at 10:12 AM.. |
The combination of shaking and torque can make surprising things... ![]()
Garage: Strosek 911 RUF BTR|Strosek 911 3.6 rat RSR|Strosek 928SR|928S4R|928S|996C2RSR|Cayenne ...and more... Altogether 13 Germans - 2 Italians - 2 British |
Squerly,
After you fix the roll bar mounts, have the car aligned and corner balanced. Make sure the tech that does the work checks thoroughly for play in any of the suspension bushings. JR |
I知 headed for Barber next Thursday for a Friday and Saturday DE and I知 excited to see how it will do. I値l change my brake pads on Wednesday and aside from hooking up my TrakMate I should be good to go. Thanks everyone, and a special thanks to Chris for his help last weekend. ![]()
A fellow Pelacanite
When I got my 911 3.2 carrera sport coupe cornered and aligned it was amazing.
Thread Tools | |
Rate This Thread | |
